![]() | Home > In Car Electronics > DAB aerial - what type and where to place ? |
jont Member Since: 02 Apr 2011 Location: Aylesbury, Bucks Posts: 242 ![]() ![]() |
As part of my xmas ICE project (tweeters/4 new midrange and a sub to go in the 90XS) I've been looking at getting a Pure 300i DAB unit - mainly for Planet Rock it has to be said - but am wondering what aerial to go for ...
There the 'internal' stick-on strip aerial type - that obviously can't go on the windscreen because of the heating elements - but was wondering if having it installed on one of the alpine lights was a good place ? The other type is an external 'magnet mini-sharkfin' mount - that I understand on a 'normal' car once on the roof, the steel skin helps with the reception - but I'm guessing not having a steel roof on the Defender means it a) wont stick and b) loses the additional reception effect ? ... the only thought I had was whether it would work if I fitted it to the external frame somewhere - maybe on the front door a-frame ? (and hope it doen't get nicked/knocked off !) Any othe rthoughts from those with DAB radios fitted already ? ... the Pure unit looks really tiny but seems to do everything with a usb/ipod/iphone connector as well as a 3.5mm jack input, FM pass through (if necessary) and a 3.5 jack output ... Was even thinking of ditching the OEM head unit completely and just fitting a small amp inbehind the console and just using the Pure as a tuner/switching unit ? Any thoughts/comments gratefully received ... and anyone in/around the Aylesbury/Wycombe area that wants to come over and have a look at tweeter/sub fitting is more than welcome ! TIA Jon J |
foxkilla Member Since: 01 May 2009 Location: J23 M1 Posts: 156 ![]() ![]() ![]() |
I have an amplified roof mount on mine, brilliant reception.
lukev01 Member Since: 24 Mar 2012 Location: Bedfordshire Posts: 412 ![]() ![]() ![]() |
I have the Pure Highway unit. As for placing the sticky aerial, I can see that the front windscreen isn't suitable but how about sticking it somewhere close? The cable I had with mine would stretch a good way, it is too long for my daily driver so I had to coil part of it up. 1970 Series 2A 88"
davew Member Since: 02 Jan 2012 Location: North Yorkshire Posts: 888 ![]() ![]() ![]() |
I fitted a roof mount aerial on the wing in place of the factory one. It's a combined DAB and FM aerial, works really well and is flexible. On my Range Rover I used a stick on type but there's a lot more glass in that !
This is the one I used on the 90 wing... http://www.dabonwheels.co.uk/JVC_HAL-2__DAB_car_aerial.html http://www.yorkshireoffroadclub.net/ |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 ![]() ![]() ![]() |
The sticky DAB aerial works fine on a Defender heated front screen as the heating elements Do Not extend to the sides there being about 15 cms gap between elements and windscreen edge. At least there is on mine -both sides and a 1 cm gap in the centre with no element.
![]() I've used the Kenwood DAB windscreen aerial. LANDYWATCH ![]() Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
Mine are edge to edge pretty much ![]() |
interesting thread, I'm looking to change/replace my headunit.
any pics of what these DAB Ariels look like ? |
YeomanOfTheBar Member Since: 04 Nov 2012 Location: North Notts Posts: 210 ![]() ![]() ![]() |
Plenty of options: http://www.dabonwheels.co.uk/DAB_car_aerials.html 2013 Defender 110 XS DCPU |
NormanD Member Since: 12 Aug 2011 Location: Bristol Posts: 287 ![]() ![]() ![]() |
Thought about fitting one of these to my roof rack.
http://www.panorama-antennas.com/datasheets/odp224-4bp.pdf NormanD WE191 2015 110 XS Utility 2014 VW Caravelle 180 Executive |
thanks guys, why did I think they looked like gold electronic circuit boards stuck on the glass ?
I'll try on in the alpine window, just need to ensure roof rack will not interfere (when I get one) |
You do get those - being the cheapest way to do it, they're what you're most likely to get bundled for free with your shiny new DAB radio... ![]() |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 ![]() ![]() ![]() |
i would be grateful for you opinion on this, plus how you routed the cables etc. i am thinking about a Kenwood DAB/FM radio and their aerial http://www.kenwood-electronics.co.uk/produ...ivers/dab/ thanks BM52 |
I fitted the 455 DAB head unit and used the Kenwood aerial http://www.kenwood-electronics.co.uk/produ...AB-Aerial/ fitted to the windscreen, a heated screen. It fits well and works flawlessly with the heated screen ON or OFF. Fitting this unit on an alpine window would be difficult because of the curved glass and the fact that the amplifier has to be earthed to the bodywork ( doesn't matter if it is painted , still works ok ). Cable routed down the side of the screen under plastic trim, under passenger dash shelf and up into the central dash .
![]() Here is the fitting instructions http://images.kenwood.eu/files/prod/2389/5..._Guide.pdf ![]() ![]() Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
Spent my HD bumper fund on a Kenwood DAB radio and their recommended aerial.
Fitted the aerial to the lower left windscreen and routed the cable as per WelshGas. I already had a Kenwood radio so it was just a pull out and reconnect along with the DAB aerial lead. Great sound with the Alpine Sub. I am very happy with the result, no interference at all as far as i can tell from the heated window. ![]() ![]() |
