![]() | Home > Maintenance & Modifications > Oil change |
Thud Member Since: 21 Jul 2012 Location: London Posts: 667 ![]() ![]() ![]() |
Might be air. Give it a run then have another look.
Ric Member Since: 03 Nov 2012 Location: South Yorkshire Posts: 209 ![]() ![]() ![]() |
I've done about 20miles and still saying full,
If I turned the engine over with the filler cap loose would get any air out or spray oil every where? its only a car! |
Leave it. It's full. Mine is the same. Just keep a bit in the car and you eye on it for a while.
strang Member Since: 16 May 2012 Location: Happy Valley Posts: 1385 ![]() ![]() ![]() |
Did you change the oil filter too?
Edit to add - the oil cooler in the rad can retain oil too. Euro-Leafing to infinity and beyond..... |
rossy Member Since: 29 Nov 2010 Location: Co. Roscommon Posts: 1296 ![]() ![]() ![]() |
its fine. Changed mine twice now and I always put just 6.5L in meaning to top up after a spin but its always full. I have had a bad experience with a dealer overfilling a previous car (most dealers seem to - its really annoying and can cause loads of problems -just google it and you'll see !) so I'm ultra cautious. Bear in mind also that there's 2 litres between the full and low marks on the dipstick plus the fact that this engine doesn't burn a drop compared to,say, VAG engines
