Home > Puma (Tdci) > How do I disable the alarm to change battery?
ZeDefender
Okay - p*ss yourselves laughing at this question but how do I disable the battery-backed up alarm so I can change the main battery?
I've done a (probably crap) search and I can't find anything in my (German) handbook and I suspect it should not be commonly known.
PM please?
Matt Tell someone you love them today because life is short.
Post #194855 19th Dec 2012 9:49am
Tiger
This is TD5 but should be the same.... (should be Laughing )
Your vehicle may be fitted with a battery backed up sounder,which operates as an anti theft siren if the main battery is disconnected. If it is necessary to remove the main battery, it is ESSENTIAL to adopt the following procedure to prevent the alarm from sounding
1) turn the starter switch to "on" and then to "off", then remove the key
2) Disconnect the main battery WITHIN 15 SECONDS (if it is not disconnected within the 15 seconds then the BBUS will sound as soon as the battery terminals are removed)
(Taken from LR4x4 from RAVE)
I've just fitted one of these little Censored and god they are loud Shocked
Post #194857 19th Dec 2012 9:59am
Rolling with laughter Poor old Matt. No Guts, No Glory.
Post #194862 19th Dec 2012 10:30am
It is indeed exactly this process for the Puma.
Post #194890 19th Dec 2012 12:15pm
