Home > Maintenance & Modifications > Mantec internal window guards and other stuff |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10379 |
I put lots of butyl tape on my frames and stuck the guards to it. No hole drilling, less likely to be knocked through and more importantly, no rattles.
16th Dec 2012 11:30am |
Surely they're supposed to be fixed through the plastic trim to the steel rails underneath? Darren
16th Dec 2012 12:53pm |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3748 |
Don't use the Mantec one, but the MSS versions,,
These you remove the side trim panels, and fix the guardes over the window apertures etc, and are bolted to the tub and roof brackets,, yours being screwed to the panels can not be correct !! Interested in why you think it was a ex G4 Event vehicle ?? As far as i recall, all Events 110 were in Tangiers Orange !! If you fancy a weekend trip out see This Topic California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
16th Dec 2012 6:10pm |
Thor Member Since: 17 Dec 2011 Location: Didcot Posts: 446 |
TJ101 - It all ready has the mantec ones so just need to find how to fit them properly, I feel a trip to Frogisland (Not far from my gym) coming up to see if they have a set of instruction laying around as they must've fitted some in the past.
I know it's a G4 Event one as I have had the VRM checked with the G4 owners club. The inside the engine bay is all Tangiers, as are some of the floor panels and in a couple of spots on the body work it's showing through. It was sprayed about 6 years ago apparently by the previous owner who also had a larger intercooler, remapped ECU, stainless exhaust, GKM over drive and some other bits and pieces fitted. There will be a a further respray in the future, I'm just not sure I want an Orange truck though!! LRA - Thats what I'm thinking but with the screws I have there's no obvious way of doing it. More research req'd! Greeni - Hmm, sounds good, but I will exhaust all avenues of the self tappers going into some metal somewhere. Strong people are harder to kill and generally more useful! |
16th Dec 2012 7:20pm |
Michael Brindley Member Since: 07 May 2008 Location: stoke-on-trent Posts: 85 |
Mantec ones on mine have large steel plates behind trim which have tapped holes in them.The idea ia that you glue the plates to the trim then you can unscrew guards to clean windows without removing trim.Mantec do not supply glue but recommend double sided tape.Fairly sure mantec make for genuine landrover parts so install instructions should be on Topix.
16th Dec 2012 8:24pm |
bilko Member Since: 08 Mar 2012 Location: warrington Posts: 106 |
Ok! Don't have any instructions to hand but have just check in the Haynes land rover defender modifying manual. ..page 97.
It shows that there should be a strip of metal on the inside of the window along the top of the trim. There are supposed to be captive nuts on the metal strip. Maybe the threads may be stripped. Please note it suggest using double sided tape to hold the strip in place to aid in fitting the window guard when window trim is replaced. Neil. |
16th Dec 2012 9:19pm |
Dam! Mike beat me to the reply.
16th Dec 2012 9:20pm |
Sorry, should have worded that better I have not got Mantec ones, but the MSS versions,, which are properly bolted to the body side, not stuck to plastic trims Repaint it the proper color,,, Orange as it should be, and keep her provenance California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
16th Dec 2012 9:52pm |
Bilko, Michael -Thanks both, no sign of metal behind the plastic trim so a job for the Christmas break if I can find a decent piece laying around. Hopefully one long enough to run the full length of the window guard rather than a large washer/plate type thing.
TJ - The thing is I'm just not sure I want an orange truck staring at me every time I look out the kitchen window. Don't get me wrong green laning etc it'd be cool, it's just the rest of the time plus the effort and money of getting all the other original bits like winch and stickers etc!! (I prefer my Hanibal roof rack any way, especially once it's powder coated and got a couple lights on the front and rear.) A respray won't be for some time yet, 4-5 years is realistic. If I had any thoughts/needs to sell it then I would do it orange, to keep its heritage and give it the potential to be turned back into a G4, but it's likely that the truck is going to be a keeper. As a keeper I'll go for a replay in a colour I want (probably stick to the grey and black theme). I'd defo keep the engine bay etc bright orange to show its heritage and maybe a discrete sticker some where, but that would be all. Strong people are harder to kill and generally more useful! |
18th Dec 2012 4:22pm |
