Home > Wheels & Tyres > Zeetex Vigor A/T tyre pressures
neddy
Question My son's 1987 Defender came fitted with the above tyres, could any of you fellow enthusiasts tell us what tyre pressures are recommended for road use.
Thank you, Derek Proud owner of 1962 IIA since 1971, Talyllyn Railway enthusiast.
Post #193728 15th Dec 2012 2:15pm
Zinke
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
90 or 110?
Post #193757 15th Dec 2012 4:28pm
neddy
Embarassed 90 Proud owner of 1962 IIA since 1971, Talyllyn Railway enthusiast.
Post #193925 16th Dec 2012 6:49am
lambert.the.farmer
England 1998 Defender 90 300 Tdi PU Rutland Red
It's the size of the tyres and their ply ratings that are important for pressures. Eg the owners book suggests for a 750r16 that front be 28psi and rears be 45psi. Rhubarb and custard let fly with their secret weapon.
Post #193926 16th Dec 2012 6:58am
lambert.the.farmer
Nearly forgot. Your other alternative is to work it out by axle load. On the side of the tyre it should have a maximum load at a given pressure which by using maths can be calculated into actual pressure for a given load as taken from the vin tag under axle loads. Eg 1000kg at 65psi per tyre or .065psi per kg if axle load is 1500kg max then that would be 750kg per tyre. Multiply that by the .065psi and you get 48.75psi. These figures are solely for illustration purposes and do not reflect your tyres load capacity nor the axle weights of your vehicle. Rhubarb and custard let fly with their secret weapon.
Post #193930 16th Dec 2012 7:15am
neddy
Embarassed Thank you, Sir. Slight problem the Zetex website states that for P235/70R16 the [u]maximum[/u] tyre pressure is 44psi. This would suggest that allowing for heating on the road the maximum safe would be about 40 psi.
Any thoughts?
Regards, Derek Proud owner of 1962 IIA since 1971, Talyllyn Railway enthusiast.
Post #193931 16th Dec 2012 7:38am
lambert.the.farmer
Oh ok. Do the tyres have a load index number moulded in the side wall it will probably be with the the speed index letter. Eg q 106 or h 83 etc? Rhubarb and custard let fly with their secret weapon.
Post #193934 16th Dec 2012 7:46am
lambert.the.farmer
Ok been and had a look on their web page and apparently the size you mention is good for 950lg at 44psi or .0463psi per kg.
On the basis of my 300tdi 90 which may not be the same as yours the front axle load is 1200kg or 600per tyre so that gives 27.78psi or 28psi to be easier. The rear of my truck being a non high load is 1380kg or 690per tyre so that gives us 31.95psi or 32 for simple.
Try them at 28psi and 32psi and see how it rides.[/i] Rhubarb and custard let fly with their secret weapon.
Post #193942 16th Dec 2012 8:15am
neddy
Embarassed Sorry, David has just taken CDZ5594 to work so I will have to wait until he gets home. Derek. Proud owner of 1962 IIA since 1971, Talyllyn Railway enthusiast.
Post #193944 16th Dec 2012 8:26am
lambert.the.farmer
I don't think the axle weights will be all that different between a turbo and a late tdi. But if they are put them in to the maths above and run them through again. What you will also find is that the size you have is actually the disco tdi size and was never offered as an option on the ninety. That said I would have them on mine as I think they look cool. Rhubarb and custard let fly with their secret weapon.
Post #193945 16th Dec 2012 8:37am
Zinke
I would start at 28 front and 34 rear and see how that works, from my own personal experience i would think you will end up with 30 front and 35 rear for mostly road work. For off road i would go for 28 all round if your not carrying too much in the back and for towing a big trailer on road i would go 30 front and 40 rear. All pressures in PSI.
Pete.
Post #193994 16th Dec 2012 12:43pm
