Home > Off Topic > Central Heating: Timed heating vs room stat controlled
excossack
Currently we have a Vaillant Combi boiler that is controlled by timer for heating so on x hours in the morning then on for x hours in the evening,
The last plumber/heater person that came out when then diverter valve packed in suggested that it would cheaper to run the boiler with a room stat and set the stat at say 20degc and let the boiler do its stuff rather than timed
Both of us are out in work during day at various times (no kids just cats)
Has anyone gone from timed heating to stat controlled heating? Did it save money? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #193305 13th Dec 2012 9:41pm
kingofthesparks
Location: Very close to Watford gap services , northants
United Kingdom 2012 Defender 90 Puma 2.2 HT Fuji White
Yes makes sense everytime just leave it at your desired temp and let it do its thing all year round Thumbs Up
Post #193308 13th Dec 2012 9:45pm
Landlord
United Kingdom 2007 Defender 90 Td5 HT Cairns Blue
You should be using both for combi with radiators, different setup for underfloor heating.
Set TRV's half way, room stat at about 19 / 20 degrees and the timer for about 3+ hours in the morning and 5+ at night depending on weather seasons.
During periods of prolonged cold spells I have run the heating 24/7 with room stat set at 20 degrees. This gives best economy with adequate heating.
We run a number of houses and use this setup to achieve best heating at acceptable costs. 2007 TD5 90 Hard Top
Post #193314 13th Dec 2012 9:51pm
Dave-H
England 2007 Defender 90 Puma 2.4 HT Tonga Green
Likewise, i've never used the timer, our heating is 'on' constant .... we just turn the stat down to 17-18 overnight and when out at work, and set it to 20-22 when home/weekends.
Happy with my bills, cheaper than next doors Thumbs Up Guns and Landrovers .... anything else is irrelevant.
Post #193315 13th Dec 2012 9:56pm
landy andy
Depends on construction, insulation of the property.
Most uk properties are not built/insulted good enough to retain heat, so a timed thermostat controlled system is normally best.
Andy
Post #193321 13th Dec 2012 10:13pm
noworries4x4
I have been told by various heating engineers that you should turn the water temp right up to max and then use both room/radiator stats and a main central control stat set to 20deg. 1hr on before you get up for 2hrs and then all evening while you are home and 24hrs over the weekend. Do not turn system off if away for a long weekend as takes to long to heat the house up again might as well have just left it set as above. If everything is under control you are not going fast enough.
Every Day 16 MY Discovery 4 Commercial Workshop and Escort Vehicle
Weekends 07MY L322 TDV8 Vogue SE
No Worries 4X4
Post #193343 13th Dec 2012 11:09pm
landy andy
I assume when you say 'turn the water temp up to max', you are talking about the boiler stat not the water as in the DHW? As this would be dangerous due to scalding and also cause excessive scale in most systems.
Andy
Post #193361 14th Dec 2012 5:02am
Hot Water 24/7
CH 24/7 with rads turned off in Rooms with Log Burners inc Hall way as latent heat from the burners keeps the hall tosty
Post #193366 14th Dec 2012 6:44am
excossack
Interesting replies chaps - thanks
The house is a 3 bed semi 1975 MY.
Cavity insulation, loft insulation (loft has Upvc facias with vents all round to allow it to breathe)
Windows all UPVc
The rads are a selection probably of the older type, single panel single convection, double panel single convection and one rad double panel double convection. I will next year replace the older ones with new DP DC rads. The bathroom rad is a towel one. 1999 Defender TD5 110
Regards
John M0VAZ
Post #193387 14th Dec 2012 8:24am
LR90XS2011
Sounds Like my set up, timer on the boiler and thermostat in the lounge that overrides the timer set at 20c heating comes on 30mins before I get up and switchs off 30mins before I go out, and comes on 30 mins before I plan to get home and goes off at my usual bed time, I also have thermostatic valves in all rooms except the lounge all set at 3 so no individual rooms get hot, all my rads are acova (old school tube type) and wow to they throw out some heat, bill for a 3 bed 1960s semi is about £750pa with British Gas DEFENDER 90 TDCI XS,
Post #193566 14th Dec 2012 8:03pm
Dave-H
£750pa .... Shocked
Also a 3 bed semi, circa 1964 ... i pay £48 per month, and it's always in credit Razz
Even happier now Cool Guns and Landrovers .... anything else is irrelevant.
Post #193573 14th Dec 2012 8:49pm
LR90XS2011
Dave-H wrote:
£750pa .... Shocked
perhaps I need some more insulation!! Sad DEFENDER 90 TDCI XS,
Post #193581 14th Dec 2012 8:53pm
walfy
Bloody hell you lot. I live in a 3 bed terrace house in Brizzle. Centre of 3 houses so not a small typical terrace house. Cavity wall down front and back, 12" of insulation in the loft, new double glazing last year all round. I have an 8KW log burner in living room. Over the last 3 bills, given 3 monthly my bill has averaged 13 quid a 1/4!!!!! Thumbs Up Thumbs Up
We turn the CH on twice through the winter to stretch it's legs. Woodburner is running most nights and warms the whole house through. The only other gas powered appliance in the house is the hob for cooking.
I couldn't cope with paying 40quid + every month for gas!!!!
Wood is free but I have to drive best part of 200 miles to get it so I reckon 2 1/2 ton costs me 80 quid. Plus if the tree surgeon I get it from is working in my area I get the nod and collect direct from site. Nice if it's ash. 110 D250 SE HT
110 USW SOLD
RRE HSE Dynamic Gone, wife killed it
VOLVO XC60 R Dynamic with some toys
Polaris RZR 900XP SOLD
Post #193586 14th Dec 2012 9:00pm
noworries4x4
£750 pa wowsers
3 bed bungalow we dont spend that much for our dual fuel from British Gas. And then we get a load back for selling them our solar power. If everything is under control you are not going fast enough.
No Worries 4X4
Post #193590 14th Dec 2012 9:04pm
Retroanaconda
I'm in the "lucky" position of living in an 18th century terraced house. Single-glazed all round, and no insulation whatsoever. Suffice to say the heat gets out pretty easy! Oil-fired heating as well. There's an open fire too which is a bonus I guess. No idea what my bill will be, but I would imagine it'll be the wrong side of £500 to re-fill the tank in the spring Sad
Looking forward to moving to a more modern property in the future, with insulation and double glazing and mains gas. Added benefit of a gas hob, can't stand these damn electric ones Sad
Post #193592 14th Dec 2012 9:10pm
