![]() | Home > Tdi > coolant loss |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8205 ![]() ![]() ![]() |
leaking out the bottom of the water pump gasket and dripping onto exhaust manifold? just very little so cant see the level drop.
tighten the bottom bolts Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
WarPig Member Since: 05 Dec 2009 Location: Sheffield Posts: 1748 ![]() ![]() ![]() |
Had a similar problem once. My coolant level kept dropping and it ended up being the water pump gasket.
Lift the bonnet with the engine running and pull on the accelerator cable whilst looking at the water pump. You may see tiny drops of coolant splashing out. Or you may see coolant splashed around the engine bay where it has leaked from the water pump. With mine I noticed tiny sprays of coolant coming out. If your going to the trouble of fitting a new gasket then you may as well fit a new pump while your at it. |
