Home > Puma (Tdci) > Upgrade - heated front windscreen
lornick
Scotland 1988 Defender 90 300 Tdi HT Epsom Green
Hi guys,
I have a Sept 2007 90 CHT and would like to up-grade the windscreed to the heated version. Is this straightforward - buy windscreen and wire in a switch - or more complicated than that?
Anyone else done it?
Any views/comments would be more than appreciated.
Thanks
Nick R
Post #18162 11th Nov 2009 12:21pm
nicks
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Alaska White
the wiring should be there, its on a timer so you would need switch, timer relay.
Post #18167 11th Nov 2009 12:45pm
Grockle
on thre td5 there isn't any wiring for the heated screen,if it wasn't an XS or if not a factory fitted option,you will need a loom making up and you'll need two timer relays and the switch,so I bet the Puma is the same. 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #18169 11th Nov 2009 2:03pm
Willie
United Kingdom 2007 Defender 90 Puma 2.4 CSW Rimini Red
Hi Lornick,
When I purchased my 57 reg Puma CSW I asked the dealer about having a heated windscreen installed. He said that it was a simple job and that I would only have to buy a switch and windscreen of course as the wiring loom was already installed.
Its a must add on for me when I manage to get the wonga.
Willie Defender Virgin
Post #18194 11th Nov 2009 10:02pm
cradgebank
England 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Wiring is NOT there on my 57 County. Richard
Either a 90, 110 or 130.
Discovery 5
Post #18205 12th Nov 2009 4:49am
dgardel
Italy
using my glass insurance after a stone taken in highway I installed the heated front screen.
IF YOUR CAR HAVEN'T HEATED SCREEN FROM LR AT THE ORIGIN, YOUR CAR IS WITHOUT THE NECESSARY WIRES!!!! Big Cry Big Cry Big Cry
You have two way to follow for a good installation....
..........remember that the heated screen is a big current charge (drain 290W/12V=24 A and more).
so you make the circuit independent from the acc. key you can discharge the battery in few hours!!!
1. you build a new wiring kit, with new fuse(s), a timer, relays and more with the attention to make all circuit under the "I" acc. key position (see upper row) .
2. you build the wiring loom like the Land Rover wiring diagram.
I take the 2nd way but you must know that, if you want the LR loom basics, there is a lot of "fine" work......
first
you need a signal form the dash board, the "Engine RUN" signal, able to switch on the heated screen ONLY with the engine running, (but the cable doesn't exist on the original loom if your car, like mine was build without heated screen installed from the origin).
second
you need a new wire (15A fused) from the ignition key but it's simple.
Third
if you put the relay and the timer (this last one bought original from LR) under the passenger seat (mine is LHD) you must place the wiring loom to under bonnet and enter into the car, crossing the gearbox housing bell (like the original wiring loom)
last but not the least you must use the GROUND point like LR (one from the gearbox) and one from the grounds junction box under the bonnet near (rear) the cooling water expansion box.
if someone wants, I can make a copy of my "P&I" schemes, ask to daniele.gardellin@me.com
The most difficult jobs are look for a right pin for add it into the dashboard connector for pick up the "engine RUN" signal......... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #18224 12th Nov 2009 10:56am
lornick
Thanks guys,
As usual, seems to be mixed messages from our respective Land Rover dealers.........
Still, it's something I want to do, so I'll get myself organised and let you know how I get on.
Cheers,
Post #18253 12th Nov 2009 9:24pm
dgardel
Italy
ah!
I'm forgetting......
it's no so simple to look for the "Heated front screen" wiring loom side connector....
it is necessary to search an a rover car on a car cemetery or buy one (and modify a little plastic guide with a cutter)
I bought it here http://shop.dingocroft.co.uk/acatalog/Electrical_Miscellany.html Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #18264 12th Nov 2009 11:36pm
MUF
United Kingdom 2007 Defender 90 Puma 2.4 HT Stornoway Grey
Cheapest way:
Tap your screen with hammer until crack!
Ring Insurance and claim for screen (£25 excess NFU)
Autoglass will ask you which defender screen you want as there are several on the system for the PUMAs
Tell them heated version. Arrange Fitting!!
Take to independent auto electrician and explain scenario.
Job done £40 + £25 excess
Still waiting for FROST to try out!
Bow down Love in this order; Burnley FC, Defender, Kids, Wife, LOL
Post #18343 14th Nov 2009 10:53am
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
Once the wife has made your breakfast;
Send her out to start the defender and spray the windscreen with de-icer, tell her to stay there until your seats warm.
Finish breakfast, kiss wife good bye sorted Thumbs Up Original Member Pie n Pea Club.
110 HCPU Tipper
Post #18344 14th Nov 2009 11:16am
MUF
Could front screen be wired to same switch as rear screen?
If not, why not?
Question
Rolling Eyes Love in this order; Burnley FC, Defender, Kids, Wife, LOL
Post #19295 1st Dec 2009 10:39pm
Grockle
If not, why not?
Question
Rolling Eyes
no you can't,to much load and fifferent relays needed,see my previous post Thumbs Up 2.4 90 XS
Post #19303 2nd Dec 2009 9:02am
dgardel
Italy
If not, why not?
Question
Rolling Eyes
NO! for two reasons:
1. Heated front screen need 270W-290W (rear screen only 75W) so you need the control that the front screen can be defrosted ONLY if the engine is running (the engine not only the key)
2. for the same reasons the Front screen ECU switch off screen after 7 - 8 min. (rear screen is always on until you switch off it or switch off the engine) Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #19314 2nd Dec 2009 11:04am
dgardel
Italy
SOrry I wrote the post very bad!!! Embarassed (grammatically, remeber I'm Italian Wink ) Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #19315 2nd Dec 2009 11:06am
Pob
United Kingdom 2008 Defender 110 Puma 2.4 HT Rimini Red
If only my Italian were a quarter as good as your English I would be pleased Wink 110 Hard top
Post #19334 2nd Dec 2009 4:31pm
