Home > Puma (Tdci) > Alarm.... |
warren Member Since: 14 Oct 2009 Location: East Lancs. Posts: 903 |
Is that one of the signs that the battery on the fob is almost due for changing?
6th Dec 2012 5:48pm |
Vera Member Since: 08 Oct 2012 Location: Nuneaton Posts: 130 |
Dunno. Tried both fobs, but I'll give it a go '09 SVX #200 '10 Morphy Richards.. I mean Prius |
6th Dec 2012 6:03pm |
TR51 Member Since: 17 Apr 2012 Location: Dorset UK Posts: 333 |
Sounds plausible, although have a look at the indicator light on dial.
I believe that: If the light flashes rapidly for 10secs when the lock is pressed then adjusts to a slower frequency the alarm is armed. If the light flashes rapidly for 10secs when the lock is pressed but FAILS TO ADJUST after 10secs to a slower frequency, the fob battery needs replacing. |
6th Dec 2012 6:12pm |
Tried a new battery. Same issue. But with both fobs, new and old battery, the dash indicator light flashes rapidly then slows to a regular rate. Hmmmmmm '09 SVX #200 '10 Morphy Richards.. I mean Prius |
6th Dec 2012 7:35pm |
Paul55 Member Since: 03 Feb 2009 Location: Somewhere in my head! Posts: 511 |
Could it be that a fuse has blown!
same thing happened to mine, took it to hunters land rover and they just replaced fuse Cogito ergo sum |
6th Dec 2012 7:55pm |
landyman37 Member Since: 22 Jan 2012 Location: west midlands Posts: 153 |
When you changed the batteries did u hold the button down with them out to reset the counter in the fob.
Phil |
6th Dec 2012 8:42pm |
Emmmmmmmmmmmmmm. Don't think so,.. '09 SVX #200 '10 Morphy Richards.. I mean Prius |
6th Dec 2012 9:36pm |
That's what you had to do with the disco 1 |
6th Dec 2012 9:41pm |
Ok... So I did the totally un-Manley thing. I looked in the manual. All good now '09 SVX #200
6th Dec 2012 10:52pm |
So how did you fix it |
6th Dec 2012 10:56pm |
Changed the battery again. But this time within 30s of turning the ignition off and by pressing one of the controller buttons after the old battery was removed and the new one put in . as per the manual '09 SVX #200
7th Dec 2012 9:12am |
Brand new batteries in both fobs, and its doing it again grrrrrr
Any ideas? '09 SVX #200 '10 Morphy Richards.. I mean Prius |
7th Dec 2012 8:04pm |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 |
You could try resynchronising the fobs to the 10AS. They do go out of synch sometimes and the pre programmed easy resync is to lock and unlock the defender 2 times using only the fob and then repeat the process with any other fobs that you have. If the problem is still apparent repeat the above process but do it 4 times instead of 2 with each fob, this is then a full resync. If that doesn't work then you will probably need to go and find some one with a diagnostic tool to check the 10AS ECU for trigger events/DTC's, I would then do a relearn of the key fobs to eliminate that as the cause of your issue
Click image to enlarge Brian Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
8th Dec 2012 1:33pm |
Thanks Brian Tried the easy resynch but to no avail, so I think a full resynch is in order... Downside is that the security card seems to be missing, so a call to the dealer is in order. Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated '09 SVX #200 '10 Morphy Richards.. I mean Prius |
10th Dec 2012 12:27pm |
