Home > Puma (Tdci) > Alarm....
Vera
2009 Defender 90 Puma 2.4 SVX Soft Top Santorini Black
Alarm....
Not sure what's going on, but got into the Landy tonight and when I disarm/arm the alarm, the indicators have stopped flashing. Was working fine yesterday for sure, can't be certain about this morning. Wasn't paying attention. But it was certainly ok yesterday....
Thoughts on a postcard please. '09 SVX #200
'10 Morphy Richards.. I mean Prius
Post #191345 6th Dec 2012 5:05pm
warren
England 2009 Defender 90 Puma 2.4 HT Santorini Black
Is that one of the signs that the battery on the fob is almost due for changing?
Post #191355 6th Dec 2012 5:48pm
Vera
Dunno. Tried both fobs, but I'll give it a go Smile '09 SVX #200
Post #191358 6th Dec 2012 6:03pm
TR51
France 2014 Defender 110 Puma 2.2 SW Corris Grey
Sounds plausible, although have a look at the indicator light on dial.
I believe that:
If the light flashes rapidly for 10secs when the lock is pressed then adjusts to a slower frequency the alarm is armed.
If the light flashes rapidly for 10secs when the lock is pressed but FAILS TO ADJUST after 10secs to a slower frequency, the fob battery needs replacing.
Post #191360 6th Dec 2012 6:12pm
Vera
I believe that:
Tried a new battery. Same issue. But with both fobs, new and old battery, the dash indicator light flashes rapidly then slows to a regular rate. Hmmmmmm '09 SVX #200
Post #191379 6th Dec 2012 7:35pm
Paul55
England 2008 Defender 90 Puma 2.4 XS CSW Santorini Black
Could it be that a fuse has blown!
same thing happened to mine, took it to hunters land rover and they just replaced fuse Embarassed Cogito ergo sum
Post #191385 6th Dec 2012 7:55pm
landyman37
When you changed the batteries did u hold the button down with them out to reset the counter in the fob.
Phil
Post #191409 6th Dec 2012 8:42pm
Vera
Phil
Emmmmmmmmmmmmmm. Don't think so,.. '09 SVX #200
Post #191430 6th Dec 2012 9:36pm
landyman37
Vera wrote:
Phil
That's what you had to do with the disco 1
Post #191432 6th Dec 2012 9:41pm
Vera
Ok... So I did the totally un-Manley thing. I looked in the manual. All good now Embarassed '09 SVX #200
Post #191457 6th Dec 2012 10:52pm
landyman37
So how did you fix it
Post #191459 6th Dec 2012 10:56pm
Vera
Changed the battery again. But this time within 30s of turning the ignition off and by pressing one of the controller buttons after the old battery was removed and the new one put in Smile. as per the manual Embarassed '09 SVX #200
Post #191504 7th Dec 2012 9:12am
Vera
Brand new batteries in both fobs, and its doing it again grrrrrr
Any ideas? '09 SVX #200
Post #191693 7th Dec 2012 8:04pm
Lorryman100
You could try resynchronising the fobs to the 10AS. They do go out of synch sometimes and the pre programmed easy resync is to lock and unlock the defender 2 times using only the fob and then repeat the process with any other fobs that you have. If the problem is still apparent repeat the above process but do it 4 times instead of 2 with each fob, this is then a full resync. If that doesn't work then you will probably need to go and find some one with a diagnostic tool to check the 10AS ECU for trigger events/DTC's, I would then do a relearn of the key fobs to eliminate that as the cause of your issue Thumbs Up
Brian
Post #191795 8th Dec 2012 1:33pm
Vera
Brian
Thanks Brian
Tried the easy resynch but to no avail, so I think a full resynch is in order... Downside is that the security card seems to be missing, so a call to the dealer is in order.
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  '09 SVX #200
Post #192292 10th Dec 2012 12:27pm
