Home > Td5 > Anybody fitted a rev counter?
Page 2 of 5 <12345>
simon119
United Kingdom 2000 Defender 90 Td5 HT Rutland Red
Do any of you that have fitted a rev counter to a TD5 know the VDO part number for the counter, not the LR part number??
My dad does work for VDO, if someone knows their part number i'll get him to make a few inqueries next time he is there. See if there are any out the back as it were.
Simon
Post #181919 4th Nov 2012 10:51am
Steve B
United Kingdom 2000 Defender 90 Td5 SW Caledonian Blue
The part in mine is a 333 015 009K.
Steve
Post #181955 4th Nov 2012 12:56pm
me@td5.org
2000 Defender 90 Td5 HT Epsom Green
me@td5.org wrote:
I don't think it would be quite as simple as just switching to 4cyl but I suppose if we don't try we will never know. A simple assumption would be that the ECU sends out a wave that has a frequency the same as the engine speed. When I get my defender back I'll try and find out what it is doing.
Hmm, it seems it is almost that simple. This is based on internet research as I haven't yet been able to test it on the car.
The signal out from the ECU gives 2 pulses per revolution, much the same as most 4cyl petrol cars. So the frequency is not a problem the problem is the signal strength which would need to be at 12v rather than 5v. Not too difficult to fix though!
edit: Elsewhere the internet says it's a 12v output..so it seems the only way to be sure will be to test it. If it works then a £35 TIM Tacho and a £5 box of electronics may do just what we all need!
Post #182002 4th Nov 2012 4:12pm
bob neville wrote:
Jon is correct if you have ABS/TC - you have to tap into the existing wire on 19 Thumbs Up
<snip>
If you move the temp and fuel gauges along to the right so that the rev counter is next to the speedo you may have/want to extend some of the gauge wires as it is a bit tight.
The only other thing you need to do is find a SWITCHED 12v supply for the gauge (not the purple from the clock as that is permanently live), an earth for the gauge and the +/- for the lights.
All the extra wires are easy to run from the existing gauges, either splice in or use piggy back spade terminals (especially for the lights).
Bob
Thanks Bob and Jon. Mine does have ABD/TC so I'll have to tap into the existing line, I guess. I'll find the other connections from somewhere convenient behind the dash.
For the lights, I expected to re-use the existing one for the clock and just move them around to suit the gauges in their new positions. Darren
Post #182029 4th Nov 2012 5:28pm
farmer giles
when J E Engineering sorted out my TD5 with a rev counter they relocated the clock in a pod by the rear view mirror. Croytec used to sell similar types of pods that might fit?
hope this helps
Post #182200 5th Nov 2012 10:04am
Thanks FG, that's an interesting solution. Unfortunately though, I'm going to be having a rear view camera screen there. Darren
Post #182306 5th Nov 2012 4:17pm
I.AM_a driver
Scotland 2002 Defender 90 Td5 CSW Oslo Blue
the standard analogue clock has one connector which includes the lights and the permanent live, so if you're using the ground from the clock for the tacho then you'll need a separate or piggy-backed ground for the illumination.
I didn't bother relocating the analogue clock as I use the digital clock on the stereo. Mark S
CONVOY for HEROES
www.facebook.com/convoy4heroes
www.lothian4x4response.org
Td5 90
Thread in 'My Defender' Forum
Post #184020 11th Nov 2012 3:33pm
chinnus
2001 Defender 90 Td5 ST Coniston Green
did we get to the bottom of what the output of pin 19 on the ECU is? If that is enough to drive the VDO tacho then you wont need to spend the extra 30 odd quid to get the modified VDO tacho from croytec
Post #188459 26th Nov 2012 8:16am
The VDO one that I have (which is now for sale) is a modified one that is designed to work from the output of pin 19. Darren
Post #188460 26th Nov 2012 8:26am
me@td5.org
I hope to have put a scope on it by the end of the week when my Defender is back. But as Anorak has one up for a reasonable price I'd snap that up.
Post #188462 26th Nov 2012 8:39am
chinnus
Is the modified VDO unit, actually modified?? Has anyone found out?
Kind regards
Post #191176 5th Dec 2012 3:05pm
davew
England 1990 Defender 90 V8 Petrol PU Auto Rioja Red
The output of the ECU is 5v 4 cylinder. I use a simple pull up circuit (transistor and a couple of resistors) to convert it to 12v and it will work with any electronic compatible tacho. I have seen a TD5 ECU with a 12v output BUT that had ABS connected and we never got to the bottom of why that particular vehicle was outputting 12v when all the ones I've seen since are 5V.
This is a "standard" mod when using a Compushift driven auto box with the TD5 as the Compushift needs a 12v input. http://www.yorkshireoffroadclub.net/
Post #191193 5th Dec 2012 4:10pm
me@td5.org
Dave is that just using a single transistor switch or a darlington driver?
Post #191230 5th Dec 2012 6:38pm
davew
Just a transistor, as long as the Tacho is happy with a digital input rather than expecting a signal from the coil -ve then a transistor is fine. Most of the after market tachos these days are happy with a digital input.
I use something like this...
The 2.4K resistor can be reduced a bit if needed and can certainly be larger (up to around 10K) depending on the current requirement of the tacho. I wouldn't go smaller than 1K for either resistor, if anything go a bit bigger. This circuit inverts the signal but that doesn't really matter.
There are all sorts of variations that would work just as well, this just happens to be the one I use for both TD5 and Megasquirt tacho drivers. http://www.yorkshireoffroadclub.net/
Post #191278 5th Dec 2012 11:17pm
me@td5.org
Cheers, I will experiment.
Post #191294 6th Dec 2012 7:28am
Page 2 of 5 <12345>
