Home > Maintenance & Modifications > Hand brake not coming on when hand brake applied
ronwong
2012 Defender 110 Puma 2.2 SW Orkney Grey
Puma 2.2 110xs, 1 month old, when i turn the ignition to III, handbrake like comes up with all the abs, tc, engine etc for a few seconds and go off, as usual like the start up cycle, but when they go off, the handbrake light goes off too, event though the handbrake is engaged, pulling up and putting down, but no handbrake light, the brake itself is working, ie engaged when pulled up and released when lever down, but the light dont reflect.
Post #191123 5th Dec 2012 12:19pm
loose connection? KEEP CALM AND Drill ON
Post #191128 5th Dec 2012 12:31pm
MartinK
The park brake switch is on the handbrake assembly, you could remove the shroud on the handbrake and make sure it's working OK...? Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #191130 5th Dec 2012 12:45pm
Glynparry25
As above..... I had the same with mine from dealership (when new). I reached under the vehicle and put the plug (single wire) on (it was hanging along side the transmission).
No problems since then Thumbs Up
Glyn Dog Sheep
Post #191131 5th Dec 2012 12:56pm
ronwong
so it should be reached on the underside? or take off the rubber on the top side? A picture would be great if possible, sorry I am not hands on yet, but bringing it in to dealer will be much effort plus labour...
Post #191284 6th Dec 2012 2:29am
Glynparry25
If you start by pulling back the handbrake gaitor youy will have something like this:
The switch (2) is bolted to the main bracket (1). Make sure the connector (16) is attached. If you can't see the connector/wire at all, look underneath the vehicle to see if it has fell through.
Glyn Dog Sheep
Post #191287 6th Dec 2012 5:51am
ZeDefender
On mine, almost from new, the switch on the handbrake lever was knackered. First stuck on, then off.
Bought a new one for a few quid and saved on the diesel by not driving to the dealer.
Censored easy to do from inside Thumbs Up Tell someone you love them today because life is short.
Post #191288 6th Dec 2012 5:52am
ZeDefender
You're up early Glyn Laughing Tell someone you love them today because life is short.
Post #191289 6th Dec 2012 5:54am
ronwong
nice, thanks a million!
Post #191290 6th Dec 2012 6:01am
ZeDefender
Nice pic from Glyn, as ever Thumbs Up
One more thing - be careful when you pull back the rubber gaitor - it's held in place by a couple of small plastic pin-clips (not on the diagram) and the rubber is easy to tear. Tell someone you love them today because life is short.
Post #191291 6th Dec 2012 6:13am
pope10001
United Kingdom 1992 Defender 90 200 Tdi HT Zermatt Silver
I'll second that! Very easy to tear. Big Cry There is one as you look at the handbrake, one against the seatbox and i believe one on the back side of the cover as well???
Post #191295 6th Dec 2012 7:28am
Glynparry25
Unfortunatly I am up at 0530 every morning (0430 your time, 0330 UK time Shocked ). At least I get to finish work at 1330 Tues- Fri Very Happy . Only other down side is that I try to be in bed by 2100 which is about the same time the forum gets busy Sad .
Off Topic
Glyn Dog Sheep
Post #191300 6th Dec 2012 9:47am
ronwong
There is 3 plastic "nail" that holds the rubber, i just pry the rubber back, the connector was ok, i think (2) was stuck, just touch it a bit and all is back to normal, thanks.
Post #191991 9th Dec 2012 10:11am
Glynparry25
Thumbs Up Thumbs Up Good to hear all is sorted..... Now time to go back to happy Rovering
Glyn Dog Sheep
Post #192050 9th Dec 2012 4:59pm
