Home > Maintenance & Modifications > H4 Bulbs-Question
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
H4 Bulbs-Question
I have finished installing my Crystal Headlights and the Relay wiring loom for the headlights dip/mainbeam. A significant improvement over the standard headlamps. But despite reading various other threads I still have a couple of questions.
It would seem that there is no set wattage for the headlamp bulbs as long as they are road legal i.e.: E marked? Bow down
Are there higher wattage, E marked H4 main/dipped bulbs, available and where can you get them? Bow down LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #190648 3rd Dec 2012 7:37pm
K9F
No higher E marked wattage ones that I've seen. These may be worth a punt perhaps..... Thumbs Up
http://www.consumabulbs.com/files/bdet.php...tAod8h8AxA If you go through life with your head in the sand....all people will see is an ar5e!!
Post #190660 3rd Dec 2012 8:14pm
PIAA Extreme brilliance 55/60s are noticeably brighter that OEM 55/60s ..
Post #190663 3rd Dec 2012 8:18pm
Mal (K9F), That's exactly the one's I have although I got mine for £19.99 on E-bay so maybe worth shopping around.
I've been pleased as punch with them and combined with Crystals also has been very good. A nice white output. KEEP CALM AND Drill ON
🇬🇧ðŸ´ó §ó ¢ó ¥ó ®ó §ó ¿ðŸ´ó §ó ¢ó ·ó ¬ó ³ó ¿ðŸ´ó §ó ¢ó ³ó £ó ´ó ¿ðŸ‡®ðŸ‡ªðŸ‡ºðŸ‡¸â›½ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª
Post #190665 3rd Dec 2012 8:19pm
K9F
There you go Welshgas can't get better than a recommendation from someone with the same setup! Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #190674 3rd Dec 2012 8:39pm
dnorrishill
England 2014 Defender 90 Puma 2.2 XS CSW Aintree Green
I fitted a pair of Osram nightbreaker plus bulbs at the weekend and they are brilliant, so much better. I was going to buy the Phillips but the osram are only £11 on amazon at the moment http://www.amazon.co.uk/Osram-O472NBP-Nigh...amp;sr=8-2
Post #190683 3rd Dec 2012 8:47pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
+1 more for Philips Extreme BM52
Post #190694 3rd Dec 2012 8:58pm
keith
PRI racing.com . PIAA extreme white is what i use , expensive but amazing .
Post #190696 3rd Dec 2012 9:00pm
john adam
France 2010 Defender 110 Puma 2.4 SW Keswick Green
I bought these GE - Megalights 120%. Not yet mounted
Ciao
Carlo
http://www.gelighting.com/LightingWeb/emea...ghting.jsp 1971 88 Series IIA somewhere in Southern Italy
1989 Ninety stolen in Paris
2004 90 TD5 gone
2010 110 S Puma TDCI running
Post #190781 4th Dec 2012 9:08am
Tiger
Got some Philips X-treme Vision 100% brighter jobs
Seem a bit meh! to me
Maybe I need to ditch the standard headlamps also and get some crystals
Post #190797 4th Dec 2012 11:15am
farmer giles
just ordered some Ring +120% h4 bulbs from the bay(£12/pr). will advise of the results in my crystals when fitted
Post #190811 4th Dec 2012 12:29pm
Yes. Thumbs Up KEEP CALM AND Drill ON
Post #190823 4th Dec 2012 1:03pm
WelshGas
Thank you for all your helpful suggestions. I think I might save up for the PIAA extreme bulbs. £47 for a pair from the USA inc postage, on eBay. Thumbs Up LANDYWATCH
Post #190868 4th Dec 2012 3:50pm
ericvv
You also have upgraded E marked H4 bulbs directly from Land Rover Accessories now. Very good white light and not expensive at all. I had those before installing the Speakers which obviously is a different story again and without competition.... You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #190922 4th Dec 2012 6:12pm
The Land Rover ones are Ring bulbs. Darren
Post #190948 4th Dec 2012 7:31pm
