Home > Maintenance & Modifications > H4 Bulbs-Question |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 |
I have finished installing my Crystal Headlights and the Relay wiring loom for the headlights dip/mainbeam. A significant improvement over the standard headlamps. But despite reading various other threads I still have a couple of questions.
It would seem that there is no set wattage for the headlamp bulbs as long as they are road legal i.e.: E marked? Are there higher wattage, E marked H4 main/dipped bulbs, available and where can you get them? LANDYWATCH Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
3rd Dec 2012 7:37pm |
No higher E marked wattage ones that I've seen. These may be worth a punt perhaps.....
http://www.consumabulbs.com/files/bdet.php...tAod8h8AxA If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
3rd Dec 2012 8:14pm |
PIAA Extreme brilliance 55/60s are noticeably brighter that OEM 55/60s ..
3rd Dec 2012 8:18pm |
^^^^^^ There you go Welshgas can't get better than a recommendation from someone with the same setup! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! Last edited by K9F on 3rd Dec 2012 10:17pm. Edited 1 time in total |
3rd Dec 2012 8:39pm |
dnorrishill Member Since: 15 Jul 2011 Location: Hampshire Posts: 616 |
I fitted a pair of Osram nightbreaker plus bulbs at the weekend and they are brilliant, so much better. I was going to buy the Phillips but the osram are only £11 on amazon at the moment http://www.amazon.co.uk/Osram-O472NBP-Nigh...amp;sr=8-2
3rd Dec 2012 8:47pm |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 |
+1 more for Philips Extreme BM52
3rd Dec 2012 8:58pm |
keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2218 |
PRI racing.com . PIAA extreme white is what i use , expensive but amazing .
3rd Dec 2012 9:00pm |
john adam Member Since: 01 Sep 2010 Location: Paris Posts: 77 |
I bought these GE - Megalights 120%. Not yet mounted
Ciao Carlo http://www.gelighting.com/LightingWeb/emea...ghting.jsp 1971 88 Series IIA somewhere in Southern Italy 1989 Ninety stolen in Paris 2004 90 TD5 gone 2010 110 S Puma TDCI running |
4th Dec 2012 9:08am |
Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265 |
Got some Philips X-treme Vision 100% brighter jobs
Seem a bit meh! to me Maybe I need to ditch the standard headlamps also and get some crystals |
4th Dec 2012 11:15am |
farmer giles Member Since: 09 Feb 2011 Location: worcestershire Posts: 1299 |
just ordered some Ring +120% h4 bulbs from the bay(£12/pr). will advise of the results in my crystals when fitted
4th Dec 2012 12:29pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20480 |
Yes. No Guts, No Glory. 🇬🇧ðŸ´ó §ó ¢ó ¥ó ®ó §ó ¿ðŸ´ó §ó ¢ó ·ó ¬ó ³ó ¿ðŸ´ó §ó ¢ó ³ó £ó ´ó ¿ðŸ‡®ðŸ‡ªðŸ‡ºðŸ‡¸â›½ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª |
4th Dec 2012 1:03pm |
Thank you for all your helpful suggestions. I think I might save up for the PIAA extreme bulbs. £47 for a pair from the USA inc postage, on eBay. LANDYWATCH
4th Dec 2012 3:50pm |
You also have upgraded E marked H4 bulbs directly from Land Rover Accessories now. Very good white light and not expensive at all. I had those before installing the Speakers which obviously is a different story again and without competition.... You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
4th Dec 2012 6:12pm |
The Land Rover ones are Ring bulbs. Darren
4th Dec 2012 7:31pm |
