Home > Technical > front o/s side light not working
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
hi,
just wondering if any one has has this issue and if so any advice on the problem. if its a quick an simple i'll fix it if not i will get the dealer to look at at as i am now in my last month of warranty.
about a month ago the bulb blew so i changed it and the new one worked.
new one blew a day or so ago so replaced with a bulb i know works but it did not work when i put it in the holder. checked fuses and as far as i can see it is fuse 19 in location 18 - swapped it with location 17 and both fuses seem OK. Checked current in wire to connector and i have power, cleaned bulb holder connections and still not working..............now confused.
Confused BM52
Post #190342 2nd Dec 2012 5:57pm
Laurie
Have you checked the earth connection?
Post #190344 2nd Dec 2012 6:00pm
bm52
only at the connector to make sure it is clean. no idea where the earth cable runs to. BM52
Post #190381 2nd Dec 2012 7:40pm
DAZ110
Post #190391 2nd Dec 2012 8:18pm
Laurie
Turn the lights on then run a wire from the earth side of the lamp to the battery negative.
If the light comes on it's an earth problem.
Post #190397 2nd Dec 2012 8:29pm
bm52
Thanks Daz i'll have a look but i have'nt had a fuse blow yet. looks like another one for the elimination process.
I'll have a look tomorrow night, far too cold now Rolling Eyes BM52
Post #190398 2nd Dec 2012 8:32pm
DAZ110
Where abouts in kent are you then bm52 ?
Post #190406 2nd Dec 2012 8:54pm
