![]() | Home > Maintenance & Modifications > Land rover all in one Key fobs, same as Dgardels batches, |
Welshsurferdude Member Since: 23 Feb 2012 Location: Newport Posts: 2444 ![]() ![]() |
Hi all
I have a problem with the all in one key for my defender. I recvieved the key quite some time ago from one of Dgardels batches but unfortunately I lost the programming pod for it since then and I went to land rover dealer today to try get it programmed but they said they couldnt so what can I do? Any suggestions? Its for a 2002 double cab td5 110 and key is already cut to it. Regards Kenny 2008 Santorini Black 110 XS USW (Sold) 2015 Discovery 4.5 Black pack Firenze red XS 2008 Corris Grey 110 XS USW (sold) 2011 Santorini Black 110 XS USW (Sold) |
I found these guys really helpful
http://remotekey.co.uk/ |
I have sent them a email, my key looks the same as theirs!
I also have another bug bear, key fob range, replaced the batteries and the range is still ![]() I heard of a mod to extend the range of the wire aerial, where is this wire on a 2002 TD5 110? Regards. 2008 Santorini Black 110 XS USW (Sold) 2015 Discovery 4.5 Black pack Firenze red XS 2008 Corris Grey 110 XS USW (sold) 2011 Santorini Black 110 XS USW (Sold) |
The alarm control box is bolted to the bulkhead behind the instrument binnacle
I figured it might be, any idea of any notes as to which wire is the aerial ? 2008 Santorini Black 110 XS USW (Sold)
d j hutton Member Since: 30 Jul 2009 Location: Dorset Posts: 1044 ![]() ![]() ![]() |
Sounds like they have a reusable programmer, so play your cards right and maybe they'll lend/rent it to you
![]() Range on the one I got from Dgardel has a better range than the originals, not as far as some I have had in the past but better than the Smart car which is about 10ft! I reckon I can operate it from at least 30ft, as well as doing it from indoors. This is on a puma though. Hope you get it sorted, nothing worse than losing a bit (or worse still instructions!) DJ 1989 200tdi 90 csw 2011 110 usw Orkney grey Buy British 🇬🇧 Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html |
me@td5.org Member Since: 16 Jan 2011 Location: Warwick Posts: 856 ![]() ![]() |
Look for an orange wire with a grey trace. Pin 26 on the AS10 plug. |
thanks a lot!
what sort of wire do I need to get to replace this one before i take the dash apart! 2008 Santorini Black 110 XS USW (Sold) 2015 Discovery 4.5 Black pack Firenze red XS 2008 Corris Grey 110 XS USW (sold) 2011 Santorini Black 110 XS USW (Sold) |
Its an Orange/Slate (grey) cable 0.5mm2 and it's 180mm long as standard.
Oh that's for a pre-2002 defender but it should be the same on yours too
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
You have a pm
Thanks all, my TD5 110 was produced early 2002 so should be ok
but Lorryman has sent me a very informative PM with all the details which im very appreciative of! Is there anybody local to Cardiff that has Nanocom or MSV2 to enable me to program my keys to the 110? Regards Kenny 2008 Santorini Black 110 XS USW (Sold) 2015 Discovery 4.5 Black pack Firenze red XS 2008 Corris Grey 110 XS USW (sold) 2011 Santorini Black 110 XS USW (Sold) |
My apologies, quite right ![]() |
Porny Site Sponsor Member Since: 31 Aug 2009 Location: Sutton Coldfield - West Midlands Posts: 810 ![]() ![]() |
The Land Rover dealer is wrong...
I can programme (and supply) these keys ![]() Is the key still in its packet? Does it have the DA ** ** ** number? Ian IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
