Home > Maintenance & Modifications > Land rover all in one Key fobs, same as Dgardels batches,
Welshsurferdude
Wales
Hi all
I have a problem with the all in one key for my defender.
I recvieved the key quite some time ago from one of Dgardels batches but unfortunately I lost the programming pod for it since then and I went to land rover dealer today to try get it programmed but they said they couldnt so what can I do?
Any suggestions?
Its for a 2002 double cab td5 110 and key is already cut to it.
Regards
Kenny 2008 Santorini Black 110 XS USW (Sold)
2015 Discovery 4.5 Black pack Firenze red XS
2008 Corris Grey 110 XS USW (sold)
2011 Santorini Black 110 XS USW (Sold)
Post #188919 27th Nov 2012 4:42pm
I found these guys really helpful
http://remotekey.co.uk/
Post #188921 27th Nov 2012 4:45pm
Welshsurferdude
Wales
I have sent them a email, my key looks the same as theirs!
I also have another bug bear, key fob range, replaced the batteries and the range is still Censored as in next to the car!
I heard of a mod to extend the range of the wire aerial, where is this wire on a 2002 TD5 110?
Regards. 2008 Santorini Black 110 XS USW (Sold)
Post #188926 27th Nov 2012 4:59pm
The alarm control box is bolted to the bulkhead behind the instrument binnacle
Post #188928 27th Nov 2012 5:03pm
Welshsurferdude
Wales
I figured it might be, any idea of any notes as to which wire is the aerial ? 2008 Santorini Black 110 XS USW (Sold)
Post #188944 27th Nov 2012 5:40pm
d j hutton
England 2011 Defender 110 Puma 2.4 USW Orkney Grey
Sounds like they have a reusable programmer, so play your cards right and maybe they'll lend/rent it to you Smile
Range on the one I got from Dgardel has a better range than the originals, not as far as some I have had in the past but better than the Smart car which is about 10ft!
I reckon I can operate it from at least 30ft, as well as doing it from indoors.
This is on a puma though.
Hope you get it sorted, nothing worse than losing a bit (or worse still instructions!)
DJ 1989 200tdi 90 csw
2011 110 usw Orkney grey
Buy British 🇬🇧
Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html
Post #188946 27th Nov 2012 5:41pm
Green Machine
@Matt (FCX) - Probably best to deal with this by PM - remember anyone can see what's written here. OK, you could argue that anyone 'in the know' will already know that, but you know where I'm coming from. Thumbs Up 2005 Td5 | 90 Station Wagon | Tonga Green
Post #188947 27th Nov 2012 5:42pm
me@td5.org
2000 Defender 90 Td5 HT Epsom Green
Look for an orange wire with a grey trace. Pin 26 on the AS10 plug.
Post #188950 27th Nov 2012 5:45pm
Welshsurferdude
Wales
thanks a lot!
what sort of wire do I need to get to replace this one before i take the dash apart! 2008 Santorini Black 110 XS USW (Sold)
Post #188952 27th Nov 2012 5:47pm
me@td5.org
Its an Orange/Slate (grey) cable 0.5mm2 and it's 180mm long as standard.
Post #188953 27th Nov 2012 5:51pm
me@td5.org
Oh that's for a pre-2002 defender but it should be the same on yours too
Post #188954 27th Nov 2012 5:54pm
Lorryman100
You have a pm Thumbs Up
Post #188975 27th Nov 2012 6:33pm
Welshsurferdude
Wales
Thanks all, my TD5 110 was produced early 2002 so should be ok
but Lorryman has sent me a very informative PM with all the details which im very appreciative of!
Is there anybody local to Cardiff that has Nanocom or MSV2 to enable me to program my keys to the 110?
Regards
Post #188983 27th Nov 2012 6:46pm
My apologies, quite right Bow down
Post #189038 27th Nov 2012 8:39pm
Porny
Site Sponsor
The Land Rover dealer is wrong...
I can programme (and supply) these keys Wink
Is the key still in its packet? Does it have the DA ** ** ** number?
Ian IRB
The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers.
www.IRBdevelopments.com
www.facebook.com/irbdevelopments
www.integrated316.com
www.facebook.com/integrated316
Post #189149 28th Nov 2012 7:33am
