![]() | Home > Puma (Tdci) > Top speed |
Bomber82 Member Since: 20 Oct 2009 Location: Alessandria - Italy Posts: 216 ![]() ![]() ![]() |
My 110 runs at 134 km/h said the GPS....
Last sunday I installed a special air filter and the top speed is increased by about 3-4 km/h. Now the 110 is to LR garage for some trouble, when it will be back to me I will test much better the top speed. I don't like it very much original configuration because if I need to overtaking a car and I need to speed up, the engine start to slow down when I reach 130 km/h and it stop to 134 km/h. Matteo Defender 110 Td4 SE MY 09 |
htrowsoc Member Since: 30 May 2009 Location: Zejtun Posts: 11 ![]() ![]() |
Mine did 160km/h last time I tried and it would have developed a bit more if the road wasn't so short
![]() It's a remapped td5 with K&n filter. I'm sure that with a couple of other mods that could be increased further. Kev |
Don't forget the parachute..... Matteo
Eduardo Member Since: 28 Aug 2008 Location: RegiĆ³n Metropolitana Posts: 2110 ![]() ![]() ![]() |
Humm,
Probably in a free fall, the Defender can reach the 200 KPH or even more. Somebody like to try? You just need a fairy high cliff and a good parachute as Bomber said. Cheers! Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
discocuzzy Member Since: 16 Jul 2008 Location: surrey Posts: 1200 ![]() ![]() |
Get a re map.....
jamesbond007 Member Since: 28 Oct 2009 Location: Central Algarve - Portugal Posts: 172 ![]() ![]() ![]() |
I have a BAS remap. I have no idea if it has taken the speed limiter off, but there is no way I would go faster than 130 kmph with this medieval castle!
If I want to go fast, I take my CLK 500 (limited at 250 kmph though)! Boldly going nowhere Discovery 3 after a Defender 110 Crew Cab TD4 and a 1964 SIIA 88 Regular. |
Bundubasher Member Since: 25 Sep 2008 Location: Sandton Posts: 34 ![]() ![]() ![]() |
The reason why Land Rover installed a speed governer is not due to limitations of the Defender "Puma" but due to limitations of the drivers. The "Puma" can easily do 150 Kph. My "Puma" does 140 Kph GPS speed no problem with plenty of accelerator travel left. I Definately do not feel comfortable driving my Puma so fast. I reckon I could push it to 150 Kph GPS speed if I was loco. I have only done this speed once or twice overtaking on a straight road. It does not feel right or safe driving so fast in a vehicle as heavy and unaerodynamic as a Defender. My normal top speed on the highway is 90 to 100 Kph. Lifes a journey enjoy the ride.
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 ![]() ![]() ![]() |
I think it was actually governed by the tyres. They're rated to 82 - hence the limit. One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition |
warren Member Since: 14 Oct 2009 Location: East Lancs. Posts: 903 ![]() ![]() ![]() |
I don't feel safe on UK roads at anything above 70 in the Landy. Hit a rut or a hump on the motorway and its all over the place! Doesn't go above 60 now. And the fuel guage doesn't move as fast then either.
That is true. The last 10 kmph cost you in gas about as much as the first 110 or 120. ![]() Discovery 3 after a Defender 110 Crew Cab TD4 and a 1964 SIIA 88 Regular. |
General Grabber are rated "Q" that means 160 km/h (99,5 mph). Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
PumaGreg Member Since: 04 Mar 2009 Location: UK Posts: 80 ![]() ![]() ![]() |
But some of the tyre options available on the Puma are 'N' rated with is 87mph (I think - it might be 82). I had a 90 50th (V8 Auto) before the Puma - that had a limiter on also - 99 mph, but standard fit on that was BF Goodrich All-terrians which were Q rated (99.5mph). Greg Currently: 2013 90 2.2 Puma Base Station Wagon 1991 90 Tdi 2015 Discovery Sport 2.2 |
What's a speed limiter ? Thanks Pete A1
dm_td5 Member Since: 20 Jul 2008 Location: Arnhem Land Posts: 609 ![]() ![]() ![]() |
