Home > Puma (Tdci) > 2007 Defender 110 XS, running report
Page 3 of 4 <1234>
Nidge
Ireland 2009 Defender 110 Puma 2.4 HCPU Cairns Blue
Bought a 07 110 xs last week has about 6,000mls. on.
Have noticed ABS/ETC lights come on sometimes - Is it safe to keep driving ? or is it just a sensor problem that some seam to be having ! Confused
2007 model big improvement over the td5 !
Nidge
Post #1196 27th Jan 2008 1:31pm
TJ101
Nidge
Hi
When does it come on,, normal driving, without using brakes/throttle ?? does it come on & stay on till you restart ? California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #1199 27th Jan 2008 5:58pm
Nidge
TJ101 wrote:
Nidge
Hi
Comes on when I start he up. stays on till I restart again. Doesn't come on all the time about 1 in 3 times.
N.
Post #1207 28th Jan 2008 3:02pm
TJ101
Yep,, sounds like the ABS wheel sensor,, get it booked into your local dealer,, know problem !! California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #1208 28th Jan 2008 3:27pm
Happyoldgit
That said it will stay illuminated after you start and until you move off and accelerate.
Post #1210 28th Jan 2008 6:20pm
AndrewS
Thumbs Up
This is normal.
Post #1212 28th Jan 2008 7:36pm
Nidge
Thanks for the help - Will book it in with local dealer.
N.
Post #1215 28th Jan 2008 8:58pm
TJ101
Well, though it was time for a update !!
Not a lot to report, with only a few miles added,,now only just under the 4000 !!
First service just done, tad early mainly because i wanted the modified sump pan fitting, so as the oil was to be changed, had the service done as well,
The pan was done FOC by Land rover, and the only item i got them to look at was, in my opinion, a slight weep to the left hand swivel unit
worse than it looks in the pictures,and a lot damper that the r/hand side,,, but they say it a wet joint, and so its normal, and no fault Shocked
Still not getting decent fuel consumption, this also was mention, and they recon they have mailed Land rover about it,, but not expecting any response !! best has been 22.4 on a nice steady 70 mph 300 mile run, without the rack !! JST did borrow for a day, and could not get more the 20mpg !!
After spending a afternoon, running a new 12v power supply to the rear, down the left hand side, then over to the right , only to find LR and already fitted a accessories power point there !!! hey-ho !! Rolling Eyes
Now with the Mt's fitted, front under guards, and rail/flaps removed, ready for a trip next month !!
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #1869 11th Apr 2008 5:38pm
DAZ110
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Barolo Black
Hi,
That 12v accessory point you mention, do you mean the supply underneath the vehicle, above the chassis under the plastic cover for the rear lights?
DAZ110
Post #1870 11th Apr 2008 7:40pm
TJ101
Hi Daz
The supply i found, is hidden behind the rear lower panel right hand side,, in my case with the XS the panel with the rear speaker in,, Comes from the fuse box under the r/hand (drivers for UK) seat, 20amp fuse (No2) marked accessories on the fuse box lid,, I believe their is a second connector in the supply line,, but not found that as yet ?? California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #1871 11th Apr 2008 7:57pm
Nidge
Getting much the same fuel consumption as you are. Others seam to be doing alot better. just about getting 300 miles to a tank !!! reckon about 22/23 mpg , normal driving and has got worse since fitting roof rack and 285 bfg a/t Sad
Post #1874 12th Apr 2008 7:08pm
TJ101
Hidge
Re tyres and consumption,, remember. with 285/75?? x16 your tyre diameter is now 32.83 inch, against 31.73 of the org 235/85 x16,, so traveling further that you were before California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #1875 12th Apr 2008 8:14pm
Jas
Had a leaky O/S swivel as well, both sides now changed under warranty.
Post #1884 14th Apr 2008 7:23pm
TJ101
For solmanic
Pics of rear carpets etc with rear seats just removed
And under the second row of seats
Any more just let me know
Tim
Post #1960 24th Apr 2008 4:59pm
TJ101
Overdue for a topic update !! Shocked
Not a lot happened in 12 months,, Did 3000 odd miles round Spain/Portugal last May,, 60% of it off road, and no problems
Nov saw another trip, this time to the Peaks,, and a few lanes
Had one trip to the dealer, to check the gearbox/clutch,, and only after driving JST's 110 (2009 model year) who's box does feel a tad smother !! but surprise, surprise, they found no fault, check the exhaust/brake cyl shield , and all OK, but did improve the remote locking fob range a tad !!!
Now getting her ready for a trip to Morocco , leaving next weekend Very Happy Decided to take the 110, rather than the D3 !!
Thanks Sonic, for the lead re the alloy box's, works well :)
Post #10379 30th Apr 2009 11:11am
Page 3 of 4 <1234>
