Home > Puma (Tdci) > 2007 Defender 110 XS, running report |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3748 |
Hi When does it come on,, normal driving, without using brakes/throttle ?? does it come on & stay on till you restart ? California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
27th Jan 2008 5:58pm |
Nidge Member Since: 27 Jan 2008 Location: Kildare Ireland Posts: 817 |
Comes on when I start he up. stays on till I restart again. Doesn't come on all the time about 1 in 3 times. N. |
28th Jan 2008 3:02pm |
Yep,, sounds like the ABS wheel sensor,, get it booked into your local dealer,, know problem !! California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
28th Jan 2008 3:27pm |
Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3471 |
That said it will stay illuminated after you start and until you move off and accelerate.
28th Jan 2008 6:20pm |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3707 |
This is normal. |
28th Jan 2008 7:36pm |
Thanks for the help - Will book it in with local dealer.
N. |
28th Jan 2008 8:58pm |
Well, though it was time for a update !!
Not a lot to report, with only a few miles added,,now only just under the 4000 !! First service just done, tad early mainly because i wanted the modified sump pan fitting, so as the oil was to be changed, had the service done as well, The pan was done FOC by Land rover, and the only item i got them to look at was, in my opinion, a slight weep to the left hand swivel unit worse than it looks in the pictures,and a lot damper that the r/hand side,,, but they say it a wet joint, and so its normal, and no fault Still not getting decent fuel consumption, this also was mention, and they recon they have mailed Land rover about it,, but not expecting any response !! best has been 22.4 on a nice steady 70 mph 300 mile run, without the rack !! JST did borrow for a day, and could not get more the 20mpg !! After spending a afternoon, running a new 12v power supply to the rear, down the left hand side, then over to the right , only to find LR and already fitted a accessories power point there !!! hey-ho !! Now with the Mt's fitted, front under guards, and rail/flaps removed, ready for a trip next month !! Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
11th Apr 2008 5:38pm |
DAZ110 Member Since: 06 Dec 2007 Location: East Sussex Posts: 2035 |
Hi,
That 12v accessory point you mention, do you mean the supply underneath the vehicle, above the chassis under the plastic cover for the rear lights? DAZ110 |
11th Apr 2008 7:40pm |
Hi Daz
The supply i found, is hidden behind the rear lower panel right hand side,, in my case with the XS the panel with the rear speaker in,, Comes from the fuse box under the r/hand (drivers for UK) seat, 20amp fuse (No2) marked accessories on the fuse box lid,, I believe their is a second connector in the supply line,, but not found that as yet ?? California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
11th Apr 2008 7:57pm |
Getting much the same fuel consumption as you are. Others seam to be doing alot better. just about getting 300 miles to a tank !!! reckon about 22/23 mpg , normal driving and has got worse since fitting roof rack and 285 bfg a/t
12th Apr 2008 7:08pm |
Hidge
Re tyres and consumption,, remember. with 285/75?? x16 your tyre diameter is now 32.83 inch, against 31.73 of the org 235/85 x16,, so traveling further that you were before California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
12th Apr 2008 8:14pm |
Jas Member Since: 08 Dec 2007 Location: UK Posts: 23 |
Had a leaky O/S swivel as well, both sides now changed under warranty.
14th Apr 2008 7:23pm |
For solmanic
Pics of rear carpets etc with rear seats just removed And under the second row of seats Click image to enlarge Click image to enlarge Click image to enlarge Any more just let me know Tim Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
24th Apr 2008 4:59pm |
Overdue for a topic update !!
Not a lot happened in 12 months,, Did 3000 odd miles round Spain/Portugal last May,, 60% of it off road, and no problems Click image to enlarge Nov saw another trip, this time to the Peaks,, and a few lanes Had one trip to the dealer, to check the gearbox/clutch,, and only after driving JST's 110 (2009 model year) who's box does feel a tad smother !! but surprise, surprise, they found no fault, check the exhaust/brake cyl shield , and all OK, but did improve the remote locking fob range a tad !!! Now getting her ready for a trip to Morocco , leaving next weekend Decided to take the 110, rather than the D3 !! Click image to enlarge Thanks Sonic, for the lead re the alloy box's, works well :) Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
30th Apr 2009 11:11am |
