Home > Maintenance & Modifications > X-Tech Sound Proofing
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
Sound Prooofed the floor,
No wonder they leak no seals on tie downs
Do seem to have spayde some sort of protection under wings on the 2.2
Dynamat in, expensive though this cost 0ver 100 quid
Fitted sound proffing that came with the Mud Panels
Fitted side panels would be best to do this first due to the amount of swarf generated.
Mask off round the tub seal and used gutter sealant
Next is wood floor and T Chest. Original Member Pie n Pea Club.
110 HCPU Tipper
Post #186817 21st Nov 2012 10:16am
Nice Thumbs Up
Post #186823 21st Nov 2012 10:52am
Waldo
Gorgeous, top job
May I ask what gutter sealant you used?? Defender 90 XS TD5 (03 Reg)
Post #186825 21st Nov 2012 11:00am
Lishlandy
England 2012 Defender 110 Puma 2.2 X-Tech LE Orkney Grey
Love this! Will be analysing those pics closely over the weekend!
Did you use dynamat on the sides behind the panels mud soundproofing also?
Loads of dynamat under my desk at work at the moment haha ===================================
Steve
90 xs sw in Stonoway Grey - Sold
110 USW X-TECH
Post #186831 21st Nov 2012 11:18am
Killer90
Site Sponsor
top job mate done properly Thumbs Up them mud trims are a must i need them now Cool CSK Automotive
www.cskautomotive.co.uk
Post #186836 21st Nov 2012 11:34am
BruceT
South Africa
Why use gutter sealant?
Thank you
Post #186850 21st Nov 2012 12:54pm
RRUK
Looks like what I did in mine over the spring and summer.
In hindsight the MUD panels could do with a double thickness of foam in the side panel recesses, as once fitted there is a little give in them. 2016 D4 HSE
1982 Series 3 SWB Petrol
Post #186859 21st Nov 2012 1:56pm
geobloke
And was it worth it? is it whisper quiet inside now?
Post #186860 21st Nov 2012 2:01pm
BigRuss
Well done Willy Thumbs Up Russell
2011MY 110 XS USW Black
Post #186893 21st Nov 2012 4:33pm
willy eckerslike
Answers,
The gutter sealant was used as the foam land rover use to seal the top to the tub is crap.
I would recommend using some dynamat on the sides as well as the foam supplied with the mud panels.
Normally at 70 mph i have the radio on at vol 27 now its at 21 so a good deal quieter, I think most of the noise now is through the rear and side doors i will do these next.
Watch this space for the two major leaks i found today. Big Cry Original Member Pie n Pea Club.
110 HCPU Tipper
Post #186896 21st Nov 2012 5:01pm
ibexman
who is a good supplier for dynamat
Post #186904 21st Nov 2012 5:25pm
ibexman
opps double post Thumbs Up
Post #186905 21st Nov 2012 5:25pm
I got mine off Ebay - The 9 sheet Extreme Bulk Kit should be available for around �130 - I was lucky enough to buy off a guy who had two kits and decided not to use them for a �100 each
Post #186912 21st Nov 2012 5:52pm
willy eckerslike
If you do the floor and wheel arches you will have one sheet leftover from the bulk extreme pack. So someone needs to source a cheaper alternative that is the same spec. Original Member Pie n Pea Club.
110 HCPU Tipper
Post #186913 21st Nov 2012 5:56pm
Tiger
Is ali backed bitumen roof flashing (not lead) not a good 90% alternative?
Post #186917 21st Nov 2012 6:01pm
