Home > Td5 > TD5 Alarm
Allan
Australia 2008 Defender 110 Puma 2.4 SVX Station Wagon Santorini Black
TD5 Alarm
Hi all, I have asked this question on AULRO and now on here as my wife uses the 90 for work and it spends a lot of time in hospital car parks.
I am curious to know if the Disco 2 motion detector can be fitted to the Defender alarm and if so are the wires to attach it in the hood lining somewhere. I know in the owner’s handbook it shows it as fitted but our 90 does not have it or the backup battery pack. The harness for the battery pack is behind the left headlight but does not apperar to ever had one fitted. any help would be appreciated.
Allan
Post #184938 14th Nov 2012 9:05am
jasong4110
United Kingdom 2003 Defender 110 Td5 G4 LE Java Black
On my 110 the motion sensor is in the OS B Pillar it is connected from the black loom under the seat and goes through the seat box it is also connected into the central locking loom. I recently moved my ECU loom and you can see the white plug in the photo.
Jason.
Post #184944 14th Nov 2012 9:37am
Allan
Thanks for that, so that is the point of connection for the motion detector?
Allan
Post #184960 14th Nov 2012 11:11am
jasong4110
Allan
Yes the white plug is the connection for the central locking (the two larger wires) and the motion sensor the purple wire. it goes through the seat box and comes up just in front of the b pillar then routes up inside the pillar to the sensor.
Jason.
Post #185004 14th Nov 2012 3:14pm
Allan
Thanks for that, will have a play over the weekend.
Allan
Post #185185 14th Nov 2012 10:49pm
achuakh
Singapore 2002 Defender 90 Td5 SW Oslo Blue
On a 90, it runs up the a pillar. You should have a connector with 6 or 5 wires. 3 of which are for the motion sensor. That's white with black, black with brown and black I believe.. The other wires go to the interior light, front.
So if yours had the full works, there will be another 3 wire from this connector to the motion sensor. Mine is a farmer spec 90 with no alarm, so I had to find all the wires, make some looms, crack open the 10as to solder the cdl relay, install the motion sensor, bonnet switch with bracket, ignition transponder coil and program the thing. From the land of the most expensive land rover defenders on planet earth. At �125k for a XS 110 csw and you get to own it only for 10yrs! Please find me a good reason to stay on this island.
Post #185638 16th Nov 2012 4:42pm
Allan
Thanks all.
Allan
Post #185739 17th Nov 2012 12:10am
Lorryman100
What alarm unit is it, is it the Lucas 10AS or an after market unit?
Post #185780 17th Nov 2012 10:29am
Allan
Just the standard unit but in Australia none of the Defenders seem to have had the motion detector fitted. Our 90 or our now gone 110 S.V.X. did not have them fitted but my long gone Disco 1 did.
Allan
Post #185999 18th Nov 2012 12:22am
