Home > Td5 > Strange clutch symptoms |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5699 |
I would start with a gearbox oil change. And I would swap to fully synthetic.
Andy |
13th Nov 2012 10:11pm |
Jimb1978 Member Since: 05 Sep 2012 Location: Huddersfield Posts: 808 |
Thanks andy.
I have been meaning to order some Difflock oil ever since I bought the car but couldn't justify the expense until now. Hopefully it might make things a little better. Are there any other suggestions? I am thinking it is not the clutch itself because it won't even crunch in to gear. It just stays stuck in neutral although the gear stick will move left and right? Jim |
14th Nov 2012 7:35am |
landyman37 Member Since: 22 Jan 2012 Location: west midlands Posts: 153 |
Hi if you try and put it in gear (not forcing it in) will in crunch into gear any gear if so looks like it could be a sticking synchro as mentioned I would try some synthetic oil.
Phil |
14th Nov 2012 10:31am |
