![]() | Home > Technical > steering boss |
Extended/raised seat rails worked for me in several ways - I believe I have similar physical "attributes" to you
![]() Combine with raising the cubby (extra storage) and driving is almost comfortable ![]() p.s. I also have a deep boss but don't know why... Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6126 ![]() ![]() ![]() |
I made a boss for my momo wheel, as the supplied one was about 4" deep!
I took an old steering wheel, cut the middle splined piece out, then turned it on the lathe at work to make it "round" again, then cut a piece of 4mm plate, turned that so it was round, and cut a hole in the middle of it, welded the piece from the steering wheel into it, drilled and tapped the holes for the screws to hold the wheel on. job done. I've got some pics somewhere I'll post up. |
taffrican Member Since: 14 Jan 2011 Location: Living room Posts: 624 ![]() ![]() ![]() |
D-Jim, that would be appreciated, cheers
![]() Pessimists say the glass is half empty.. Engineers say the glass is twice the size it needs to be! |
yorky Member Since: 25 Aug 2012 Location: West Yorkshire Posts: 119 ![]() ![]() ![]() |
Ha - raising the cubby box, why didnt I think of that! Have put the seat risers on and fitted my Momo Tuner wheel with quick release boss and all is well except my left elbow is 5cm too high to rest easy on the top of the cubby. Been thinking of a extra padded cubby lid or have a surgical adaptation to my elbow! Neither would be a good idea - but raising the Cubby box is so flippin obvious - thanks Ze, its on my mod list! 90 XS Volvo V70 |
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 ![]() ![]() ![]() |
get the padded top type cubby they look great and are comfy ![]() ![]() www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
Oi!! you two, b*gger off and get yer own thread!!
![]() ![]() ![]() ![]() Pessimists say the glass is half empty.. Engineers say the glass is twice the size it needs to be! |
![]() ![]() ![]() ![]() www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
Think you've got problems.....I took advantage of the fine weather this weekend and took the boat out....Think I ought to take up a different hobby.....or get a bigger boat perhaps.... ![]() ![]() ![]() Treat every day as if it is your last....one day you will be right!! |
![]() ![]() How can you see what you're welding? Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
haha thread wrecker
OK, back in topic....
Very picture heavy this one: OK, here's how I made my steering wheel boss. The reason for it was the one I bought (as most seem to be) was HUGE! It brought the wheel a good 4 inches or to towards me, which looked ugly and made for a naff driving position. The bought boss: ![]() Click image to enlarge So I got hold of an old knackered 4 spoke wheel with the correct splines, and set about cutting the middle piece out of it with an angle grinder. Not pretty, but quick! ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge I then stuck it in the lathe at work, and turned it into a proper round shape. Then I took a piece of thick (think it was 6mm or so) plate, and cut that into a round shape on the lathe, and also cut a hole through the centre of it to take the turned-down boss from the old wheel: ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Placing this turned flat plate onto the new steering wheel, I could mark the position of the screw holes, drill them and tap them out: ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge So the middle splined boss needed to be welded to the plate: ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge I also welded a thin (1mm or so) piece of flat steel to make a skirt, just to hide the backside of the boss and make it look a bit neater. Some black paint, and job done! ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge And finally, in place; ![]() Click image to enlarge ![]() Click image to enlarge |
Thanks D-Jim, a cracking job done there, that's definitely my next job
![]() thanks for going to the trouble of uploading pics, much appreciated ![]() Pessimists say the glass is half empty.. Engineers say the glass is twice the size it needs to be! |
