Home > Puma (Tdci) > 2012 2.2 TDCi Revs drop right off during gear change |
willy eckerslike Member Since: 15 Jun 2009 Location: North yorks Posts: 1789 |
I think the 2.2 rev matches when changing gear in the higher gears, blipping the throttle or pausing too long during gear changes may cause some confusion to the engine. I know my 3.2 TDCi rev matches and makes for nice smooth change, only problem comes when changing up but not applying throttle, tends to rev match then suddenly drop off when the ecu realises you are not going to apply any throttle. Some people have had a 2.2 a lot longer than me i'm sure they will be along to put me right. Original Member Pie n Pea Club.
110 HCPU Tipper |
8th Nov 2012 7:58am |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6276 |
Steve,
this may be totally misleading however I had the following issues; pretty much from new got what seemed like intermittent rough running of engine more recently (last 6 months) I occassionally had what seemed like the engine loosing revs during gear change like you've mentioned. and on one occassion when pulling caravan up steep hill seemed like engine pinking / fuel starvation but on a mamouth scale (sounded like a very big bag of spanners. anyhow the car is now in for a new clutch and transfer box. so where it seemed like the engine was loosing revs it was likely the transmission loosing moment (for whatever reason). similar symptoms quite possibly completely different cause? |
8th Nov 2012 10:49am |
Staftly Member Since: 06 Jul 2012 Location: Lancashire Posts: 55 |
Thanks willy eckerslike and caterham, certainly some food for thought. I think I will try an adjustment to my driving style in the first instance to see if that makes a difference. Caterham, I can see the connection here, scary thought since my vehicle has only covered 4k since new, that said, I have read numerous reviews that mention transfer box issues during early life. I noticed another pronounced episode tonight whilst changing down from 3rd to 2nd to take a tight 90 degree left, I tried to blip the throttle to match the revs during gear pickup and nothing happened. It was like the throttle has temporarily ceased to work, resulting in a rather clunky gear change.
Like I say, I will try to omit the 'blip' action (something I've always done, it may prove difficult) to see if that is confusing the ecu in the first instance. Also, I have had a similar experience to Caterham whist towing a fairly small trailer, no more than 3/4 tonne at the time, It was shortly after I picked up the defender, at the time I put it down to the PDF self cleaning, maybe it wasn't after all, since it really did sound like a bag of spanners. I'll take more notice next time and ask the dealer if this is normal behaviour. Thanks fellas for giving me a few things to look out for. Many thanks, Steve |
9th Nov 2012 1:49am |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 |
DON'T ask the dealer if this is normal behaviour, as his reply will be " Of course Sir, it is a Defender ".
What I have done with such a problem, and this wasn't a Defender, was to invite someone from the Dealership to take me for a drive in my vehicle, having been given minimal information of the problem. If they cannot drive it without the problem then you'll be over the first hurdle. Just sit quietly and let them, hopefully, make a fool of themselves. LANDYWATCH Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
9th Nov 2012 8:49am |
Steve,
this is my second puma and while I owned the first one (that had various issues too) I put it down to being a defender and should have expected it to be like a tractor (an old one at that). however having experienced puma's working as they should (or so I beleive) they are in my opinion similar to any other modern car I don't believe you should be experiencing any issues ie blipping the throttle really shouldn't be a problem. there certainly shouldn't be any spanner sounder either. I sincerely hope you get it sorted. .....and wait for the following posts contridicting my above comment 'like any other modern car' ! |
9th Nov 2012 8:50am |
