Home > Puma (Tdci) > FYI bleeding fuel system
tatra805
Slovakia 2008 Defender 110 Puma 2.4 CSW Bonatti Grey
I ran dry after installing a britpart filter which was sucking air.
(before you start telling me how stupid it was, i had no choice, OEM was out of stock)
Really, how difficult can it be to copy something and make it to the same spec??? that is not even R&D.
Anyway, car died after 10 minutes of running, happily still at the parking place.
2 hours and multiple attempts later we put back the old OEM filter and immediately all was solved. Rolling Eyes
Well the good news is that taking air out of the system is not all that problematic and can be done without the special LR tool. Just need a rag, a compressor and an empty bottle to catch fuel at the engine side.
Pressurize the tank and let flow the diesel at the fuelrail (unplug the quick-connect at the front and top of the engine, next to the fuelrail, not the ones hidden lower down at the middle of the fuel rail) into the bottle, about 1 liter and no more air came out.
Just FYI in case you need a bush repair. (oh and with a 12VDC compressor it might be necessary to block your tank vent pipe)
Smile
Post #177889 22nd Oct 2012 8:13am
jst
good tip, thank you Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #177895 22nd Oct 2012 8:31am
Dieselhead
Ah your not the only one to have had problems with brit part fuel fitlers
Serviced a mates Puma yesterday.
5 mins after he took it he was at the side of the road with a dead engine Embarassed
I had to tow him to saftey, in the end I had to put the old filter back on & suck diesel up using my oil extractor
All at the side of the road
I wont use brit part again!!!!!!!!!!!!!!! Chris
2008 XS 110 2.4 Utility. Tonga Green
1953 Series 1 for restoration
1983 Mini Mayfair
2004 VW T5 Camper
2008 Diahatsu Sirion. Thats hers
Classic Bolens Garden Tractors
Post #182048 4th Nov 2012 6:27pm
Phoenix90
United Kingdom 2007 Defender 110 Puma 2.4 USW Stornoway Grey
Great tip, but how do you pressurise the tank?
Post #182065 4th Nov 2012 6:50pm
sense of adventure
United Kingdom 2010 Defender 110 Puma 2.4 USW Galway Green
If the tank is above 3/4 full just jack the rear end up 400mm and it will fill the filter for you
Post #182108 4th Nov 2012 8:29pm
Phil VM2.5
Belgium 2012 Defender 110 Puma 2.2 SW Keswick Green
hi,
if it work as you say, interesting !
the other idea to put pressure at the tank is great also but will be afraid with the pressure a tank
anyway, in which state will be all the little plastic connections in some years when we will use the official tool ?
also for the one who make offroad, what about the risk to put dird when using the official kit ?
regards,
Phil current : defender 110 sw 2.2 puma 2012 and 230.000km today and
again my Range Rover VM2.5 engine from 1992 and 528.000km today.
One ten 1988 to 1992
1987 BMW GS80
One Ten from 1984 to 1987
One Ten from 1983 to 1984
Serie 3 109 from 1980 to 1983
from 1974 Jeep CJ3B and CJ6
Post #182809 7th Nov 2012 10:17am
tatra805
bit late to answer the question
pressurizing the tank we do by "sealing" the filler opening with the rag wrapped around the air pistol. This allows for enough leaking that the pressure is absolutely not dangerous for the tank/fuel lines.
With a 12Vdc compressor which has only little flow compared to a normal one i think better sealing and even closing the breather pipe will be necessary to have some effect.
Smile
Post #182845 7th Nov 2012 12:30pm
Dieselhead
I did not.
Just pulled the pipe off the fuel rail & sucked the fuel up to there.
Cranked it round a few times & it went.
May have been luck but it worked Very Happy Chris
1983 Mini Mayfair
2004 VW T5 Camper
Post #183007 7th Nov 2012 8:25pm
Landlord
United Kingdom 2007 Defender 90 Td5 HT Cairns Blue
On a TD5 turn ignition on but do not start engine, depress and release accelerator 4 or 5 times until MIL flashes, fuel system goes into auto purge until engine is started. 2007 TD5 90 Hard Top
Post #183009 7th Nov 2012 8:30pm
paulgrs2
United Kingdom 1988 Defender 110 200 Tdi PU Baltic Blue
£14 sealey hand pump with slightly adapted pipe fittings works a treat, done loads with it.
Post #183831 10th Nov 2012 7:30pm
sense of adventure
No pump in the tank on a 2.4 but there is on the 2.2 but it needs a different sequence and tooling for it to prime
Post #183835 10th Nov 2012 7:48pm
