Home > Maintenance & Modifications > Fuel filler rubber seal.
Thud
United Kingdom 2008 Defender 90 Puma 2.4 SW Zermatt Silver
The rubber seal on my 90 is cracking. Is this seal an easy swap or requiring the garage to do it?
Thanks
Post #181567 3rd Nov 2012 8:10am
The seal that holds the filler tube thing into the recess in the bodywork?
Easy to do, it's just a push fit, although you may have to undo the jubilee clips below on the main filler pipe and breather so you can remove the whole shebang, then fit the new rubber, then refit it all in.
Post #181598 3rd Nov 2012 9:19am
If you do do the above though and dismantle the fittings make sure it's all clean first or it's highly likely that dirt or debris can get into the fuel tank and system. Thumbs Up $W33T $0U7H3RN $UG4R
Post #181608 3rd Nov 2012 9:59am
I think i've got one of those rubbers in the garage if you want it... i'll dig it out tomorrow
Post #181752 3rd Nov 2012 7:09pm
Thud
Thanks for the advise and offer chaps. Jim I'd be very grateful!
Post #181756 3rd Nov 2012 7:15pm
I found it. PM me your address and I'll stick it in the post.
Post #182042 4th Nov 2012 6:22pm
Thud
That's awesome Jim, thanks. Let me know what I owe you if even a bottle of wine.
Post #182045 4th Nov 2012 6:25pm
Nothing mate, it's just sat in a box of bits.
Post #182051 4th Nov 2012 6:34pm
Thud
Received with the gratefullest of thanks Jim and fitted in 10 minutes with no undoing of any fittings. Looks much better.
I owe you a big beer! Mr. Green
Post #183155 8th Nov 2012 12:00pm
Mine is starting to crack just a little but hardly noticeable. Guess it depends how much Diesel it gets spilt on it. $W33T $0U7H3RN $UG4R
Post #183156 8th Nov 2012 12:02pm
