![]() | Home > Td5 > Td5 regulator change and engine rattle |
wslr Member Since: 18 Jul 2010 Location: Wellington, Somerset Posts: 581 ![]() ![]() |
If you get the gasket wrong, then the leak will be very noticeable.
Even the genuine part ones don't last long. You can get rebuilt ones using better quality and purpose correct o-rings, but the internals also need a little engineering, and most of the rebuilt ones do not have this modification done. There is an o-ring located in the head which hold a very fine mesh filter (your gasket and regulator bolt over it). This O ring may be an issue perhaps, but again, I'd have expected it to leak fuel rather than pick up air. The knock may be air getting in else where such as the filter or filter head etc. |
Landlord Member Since: 27 Oct 2009 Location: Hampshire Posts: 582 ![]() ![]() ![]() |
Had mine changed this week. Learned a few things whilst it was in the workshop !
There are two different regulators, one for the older TD5 engine and an updated one for the newer TD5. I presume you got the correct one for your engine number ? The technician did mention the small gauze filter that sits just inside the engine side of the regulator mounting location as sometimes these are damaged or fall out and can be a PITA to replace. A good tip he showed me was how to bleed / purge the fuel system. Turn ignition on without starting engine, depress and release the accelerator pedal 4 or more times until the MIL light flashes and the fuel system self purges continuously until you start the engine. 2007 TD5 90 Hard Top |
AlexLandy10 Member Since: 03 Nov 2012 Location: Ipswich Posts: 15 ![]() ![]() ![]() |
thanks for the replies, i'm pretty sure I fitted the right regulator, I think the later ones had three pipes, i've checked around the filter area and cant see any signs of leaks, i've done the self purge numerous times and it makes no difference, should i risk taking the regulator off and having a look or get someone to do a fuel pressure test first? If at first you don't succeed, hit it harder or get someone else to do it.
