Home > Puma (Tdci) > Tow Ball on NAS rear Step
Nickwill
 2007 Defender 90 Puma 2.4 XS CSW Stornoway Grey
I need to tow an Ifor Williams 510 twin axle horsebox with my 90 xs fitted with an NAS Rear Step Tow bar. However, even when the tow ball is fitted to the lower pair of fitting holes on the tow bar, it is still too high. I know I could get an adjustable Dixon Bate type fitting bit don't really want it to impact ( Razz ) on the ground clearance that much. What are your views on using a fixed drop plate arrangement to lower the towball the required amount but no more? Fitting is simple and cost is less but what about safety when towing up to 3500kgs?
Advice appreciated.
Post #180864 1st Nov 2012 8:42am
TJ101
Tow ball high with the NAS rear step, is the reason a few members on here have got rid of the step,, and fitted a proper adjustable tow bracket !!
Do a search, has been a couple of threads about it, along with some iffy pictures Shocked California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #180995 1st Nov 2012 2:39pm
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
All sorted now Tj Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #181029 1st Nov 2012 5:25pm
TJ101
Thumbs Up Bet you feel better, when you are towing now Karl Very Happy California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #181036 1st Nov 2012 5:54pm
me@td5.org
2000 Defender 90 Td5 HT Epsom Green
If you have a step with holes in it for a 50mm ball it's not a NAS step. The NAS version has a reciever.
Post #181056 1st Nov 2012 6:47pm
Nickwill
No snags, many people seem to use NAS in the description, how about calling it the rear step bumper (VPLDP0095) then if this helps.
Post #181067 1st Nov 2012 7:06pm
fekete
Took your advice Tj Bow down better safe than sorry mate thanks Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #181083 1st Nov 2012 7:45pm
Nickwill
Hi Fekete, I see on another topic where you posted a piccie of your rear end !! you are using a drop plate. Can you help with the queries in my original post please?
Post #181108 1st Nov 2012 8:18pm
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
"Hi Fekete, I see on another topic where you posted a piccie of your rear end !!"
Thank god I missed that particular post Shocked Original Member Pie n Pea Club.
110 HCPU Tipper
Post #181112 1st Nov 2012 8:20pm
fekete
Rolling with laughter Rolling with laughter
Only for Alison's eye Pete Whistle NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #181119 1st Nov 2012 8:36pm
TJ101
Hi,,
You may gather, Fekete has now changed his towing equipment, I presume to get rid of the "drop plate" arrangement
The problem is, with a plate on a "NAS Style" Rolling Eyes towbar/step, The forces loaded on the ball/plate are far greater than the weight of the trailer, certainly when trying to stop it when going down hill,, or the trailer starts to "wag" !!!
The "plate/towball" would need at least some sort of bracing, leading from the bottom, back to the chassis rails,,
While i would love a step bar on mine, its of no use to me, as it spends 90% of the time when not aboard towing , with various heights of trailer hitches, i have to have the genuine slider/adjustable tow bracket California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #181226 2nd Nov 2012 8:31am
