Home > Puma (Tdci) > Software update |
YORKSHIRELAD Member Since: 17 Mar 2009 Location: West Yorkshire Posts: 159 |
Hi lads. My 110 is going to the dealers in the morning for a few bits doing. 3 blown/faulty elements in the rear heated glass,water ingress,an intermittent wiper with a mind of it's own and I wanted them to investigate the scuffing sound when I switch it off. Anyway, while it's there,will they do the ecu software update as a matter of course, or do I request it?. I sometimes have a second or so delay in power when changing from 3rd to 4th gear and wondered if it might cure it?. Thanks,
Richard 1963 Series 2A truck cab 2008 110 SW |
9th Nov 2009 12:31pm |
Cannonball Member Since: 19 Jun 2009 Location: Co Laois Posts: 150 |
Should be updated automatically but no harm to enquire, keeps them on their toes!
9th Nov 2009 12:44pm |
Thanks.On their toes,they will be!.
9th Nov 2009 12:57pm |
Ads90 Member Since: 16 Jun 2008 Location: Cots-on-the-Wolds Posts: 812 |
Yes, they should update it as matter of course (mine was) - but funny you should mention the delay going into 4th... I didn't have this until AFTER the software update - I do now!? All else re. the update was ok - haven't noticed any performance difference but I think it runs a little quieter/smoother from cold. |
9th Nov 2009 1:12pm |
CapeLandy Member Since: 21 Jul 2008 Location: Cape Town Posts: 558 |
I have the power delay in all gears. Almost a protection method to make sure the clutch is fully engaged before you are able to put power through it.
I think it may be linked to the hydraulic clutch pressure switch. Puma 110 - gone Series III 1973 - going strong |
10th Nov 2009 5:22am |
I'll report back what is said about it when I pick it up wed/thur?. Thanks,
Richard. 1963 Series 2A truck cab 2008 110 SW |
10th Nov 2009 6:27am |
110SEB Member Since: 29 Jan 2009 Location: Essex, England Posts: 1444 |
A power delay to help save the clutch seems like a good idea, since the engine is so torquey that it manages to chew up gear boxes and clutches. On the other hand i bet it could get annoying when you need the power immediately. I will report on whether ours has the delay after it's back from the dealers with its new EGR valve and clutch.
10th Nov 2009 8:29am |
