Home > Puma (Tdci) > Software update
YORKSHIRELAD
Software update
Hi lads. My 110 is going to the dealers in the morning for a few bits doing. 3 blown/faulty elements in the rear heated glass,water ingress,an intermittent wiper with a mind of it's own and I wanted them to investigate the scuffing sound when I switch it off. Anyway, while it's there,will they do the ecu software update as a matter of course, or do I request it?. I sometimes have a second or so delay in power when changing from 3rd to 4th gear and wondered if it might cure it?. Thanks,
Richard 1963 Series 2A truck cab
2008 110 SW
Post #18033 9th Nov 2009 12:31pm
Cannonball
Ireland 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Should be updated automatically but no harm to enquire, keeps them on their toes!
Post #18034 9th Nov 2009 12:44pm
YORKSHIRELAD
Thanks.On their toes,they will be!.
2008 110 SW
Post #18036 9th Nov 2009 12:57pm
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
Yes they always do mine without asking but no harm to ask rich Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #18037 9th Nov 2009 1:03pm
Ads90
United Kingdom 2007 Defender 90 Puma 2.4 CSW Keswick Green
Re: Software update
YORKSHIRELAD wrote:
...while it's there,will they do the ecu software update as a matter of course, or do I request it?. I sometimes have a second or so delay in power when changing from 3rd to 4th gear and wondered if it might cure it?.
Yes, they should update it as matter of course (mine was) - but funny you should mention the delay going into 4th... I didn't have this until AFTER the software update - I do now!? Rolling Eyes
All else re. the update was ok - haven't noticed any performance difference but I think it runs a little quieter/smoother from cold.
Post #18038 9th Nov 2009 1:12pm
CapeLandy
South Africa
I have the power delay in all gears. Almost a protection method to make sure the clutch is fully engaged before you are able to put power through it.
I think it may be linked to the hydraulic clutch pressure switch. Puma 110 - gone
Series III 1973 - going strong
Post #18068 10th Nov 2009 5:22am
YORKSHIRELAD
I'll report back what is said about it when I pick it up wed/thur?. Thanks,
Richard. 1963 Series 2A truck cab
2008 110 SW
Post #18069 10th Nov 2009 6:27am
110SEB
A power delay to help save the clutch seems like a good idea, since the engine is so torquey that it manages to chew up gear boxes and clutches. On the other hand i bet it could get annoying when you need the power immediately. I will report on whether ours has the delay after it's back from the dealers with its new EGR valve and clutch.
Post #18070 10th Nov 2009 8:29am
