![]() | Home > Technical > gear box mounts |
quigley Member Since: 20 Oct 2009 Location: Kilkivan Posts: 10 ![]() ![]() ![]() |
My car (776888) has what looks like provision for a further gearbox mount. The rear of the gearbox bellhousing is drilled & tapped, and the chassis cross-member has a bracket going up close to the bellhousing.
But there is no mount on my car using these location points. Does anybody have such a mount fitted to their car? Perhaps mine has been left off or the use of such a mount abandoned. [see attached photo at flickr.com/quigley2009/defender puma 84] [/img] |
dm_td5 Member Since: 20 Jul 2008 Location: Arnhem Land Posts: 609 ![]() ![]() ![]() |
This has come up before and the I don't think anyone actually knows what the mounting point is for but it definitely isn't used on the finished vehicle.
To Post the pic click the IMG button paste the url to the image and then click the IMG button again. You should then end up with text like this: Here is a Picture of my Tdi [img]http://farm3.static.flickr.com/2131/1504793705_7c02b4e37e.jpg[/img] Which when viewed will look like this: 110 2.4TDCi 110 300Tdi ![]() LROCV ::: AULRO.com |
LESVOSD110 Member Since: 19 Aug 2009 Location: South Africa Posts: 241 ![]() ![]() ![]() |
Mine has nothing ether,though my first thought was that it was forgotten.Gearbox might be used in another vehicle that needs a mount there or cost cutting from factory. Puma 110 SW
90 V8 SOFT TOP |
