Home > Technical > headlamp leveling is not working
fr3dg1
Switzerland 2008 Defender 110 Puma 2.4 SW Bonatti Grey
Hello,
the headlamp leveling on my 2008 110 stopped working. i tested one of the headlamp actuator it seems to react to power,
also there is some power at the connector behind the actuator. So i suspect the problem comes from the multi-position switch.
how can i troubleshoot it?
regards
fred Very Happy
Post #179651 28th Oct 2012 1:00am
K9F
Re: headlamp leveling is not working
fr3dg1 wrote:
how can i troubleshoot it? regards fred Very Happy
Hi Fred,
By using a multimeter and the diagram I've posted below....Sorry about the quality but best I can do at the moment. Good luck. Thumbs Up
 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #179680 28th Oct 2012 9:36am
fr3dg1
hello,
thanks a lot for the document, with the reference on yours i managed to find it online in a better quality.
I have to admit i understand the schematic but i would need to know voltage, ohm, or amps I'm supposed to find along the circuit.
i understand the multi position switch works by modifying the circuit resistance. how can i check the switch is functioning properly.
Best regards
link to the full document:
www.lrservice.ru/data/398/28/DEFENDER_07_VIN_732617.pdf
Post #179716 28th Oct 2012 11:09am
K9F
Ultimately check you have the following earths: (best to disconnect to prevent parallel paths):
There should be no resistance = 0 ohms.
On the headlight levelling switch (S109) contact 3
Left hand headlamp levelling motor (M130) contact 2
Right hand headlamp levelling motor (M129 contact 2
If they're ok reconnect everything.
Get someone to operate the levelling switch, with ignition and lights on, whilst this is happening you should have 12 volts DC at the following points S109 contact 2, M130 and M129 contact 1.
Should give you an indication what is/is not happening. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #179756 28th Oct 2012 2:59pm
ronwong
2012 Defender 110 Puma 2.2 SW Orkney Grey
sorry to highjack. My levelling.... one the left light work and not the right? ie, when I switch up and down the left light goes accordingly, but the right one is stuck in position 1 relative to left light. Which part or cable should I check first?
Post #345764 17th Jul 2014 9:34am
K9F
Follow the link below or the link posted by fr3dg1 in his last post and you will have access to loads of information including wiring diagrams, then follow my instructions in my previous post. The wiring diagrams can be found in the Workshop icon.
http://sdrv.ms/113CDqk If you go through life with your head in the sand....all people will see is an ar5e!!
Post #345822 17th Jul 2014 1:06pm
