Home > Maintenance & Modifications > Flexi Radio Aerial.
Page 1 of 3 123>
Thud
United Kingdom 2008 Defender 90 Puma 2.4 SW Zermatt Silver
Flexi Radio Aerial.
Would this (link below) be an easy DIY fit or would it require a specialist?
http://www.entreq.de/products/entertainmen...xible.html
Post #179258 26th Oct 2012 7:40pm
Thud
Not sure the link works. Products. Entertainment. Aerial.
Post #179281 26th Oct 2012 8:27pm
It works if you click the little 'GB' symbol, top right.
Can't see fitting being that difficult. Routing the cable through the bulkhead to the dash is likely the trickiest part. Darren
Post #179286 26th Oct 2012 8:34pm
chadjizz
England 2013 Defender 130 Puma 2.2 HCPU Orkney Grey
if you get it i would like to see how you get on.
wonder if the reception is as good or better, i would get one too if it is.
Post #179295 26th Oct 2012 8:51pm
leeds
AM: 0,15 - 6,2 MHz
FM: 87,5 - 108 MHz
Flex aerial is 350mm long and flying connection lead is 1300mm long.
Since we have a bent telescopic aerial have a couple on order so hopefully will be able to answer some of these questions more fully from a practical point of view.
However having experience the Entreq quality standard I am sure it will be top quality.
Brendan
Post #179300 26th Oct 2012 9:03pm
Thud
Will you reserve the other one for me Brendan?
Post #179370 27th Oct 2012 7:29am
Not sure where the cable runs from under the wing or even if it is easily accessible, but i would have thought it wouldn't be that hard to cut the existing cable and create a waterproof joint underneath the aerial mount (if there is not one there already).
Seems a bit OTT to have to run the cable all the way back to the rear of the head unit.
Can you also unscrew the antenna from the base plate?
Post #179379 27th Oct 2012 8:40am
Thud
I'm hoping so too.
My plan if not is to pull a piece of garden wire through when I remove the telescopic one and use the wire to pull the new cable through again.
Sounds good in principle. Big Cry
Post #179380 27th Oct 2012 8:42am
Is there nobody looking into providing a kit to fit the aerial on a side glass panel ala the rest of the LR range?
To be honest, looking closely at the Defender range for the first time recently, the 1970s telescopic aerial struck a really discordant note - even my gf commented "Really!" when she saw it...it really does not speak for quality.
It would be easy to cover up the hole with a chequerplate kit and indeed the kits I have seen fitted around the hole are nearly all never square which draws your eye in again but for all the wrong reasons. Much better to get rid of it altogether.
My alternative plan was to either fit it inside the canopy of my DCPU or even try and turn the hoops themselves into the biggest aerial possible...the latter may just be wishful thinking... Very Happy
Post #179389 27th Oct 2012 9:02am
Thud
I originally thought the motor was broken in mine. Rolling Eyes
My problem is that I always forget to extend it until I'm driving.
Post #179391 27th Oct 2012 9:04am
K9F
I looked at this one which seems an easy fit.....
http://www.bluespot.co.uk/car-audio.aspx/7617495224-aerial
Some good information on these about replacement aerials too:
http://www.defender2.net/forum/topic12030.html?highlight=aerial
http://www.defender2.net/forum/topic5241.html?highlight=aerial
http://www.defender2.net/forum/topic7353.html?highlight=aerial
http://www.defender2.net/forum/topic4928.html?highlight=aerial If you go through life with your head in the sand....all people will see is an ar5e!!
Post #179402 27th Oct 2012 9:53am
Thud
Good fitting advice above although the Blauplunkt one doesn't have Entreq engraved on it's base. Cool
Post #179417 27th Oct 2012 11:00am
K9F
Agree! But how much for a name are you willing to pay? I just paid an extra £85 for Entreq to be written on my snow cover when another brand could have sufficed! Entreq are 'synonamous' with top quality though!
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #179423 27th Oct 2012 11:32am
Lorryman100
Brendan
Excellent news Brendan Thumbs Up I was going to order one from Entreq direct, but as you are getting a spare one Whistle can I have first dibs please?
Brian.
Post #179440 27th Oct 2012 12:42pm
K9F
BU993R!!!!!
Snooze you lose! I just have! Thumbs Up If two turns out to be three....Yes please! Laughing If you go through life with your head in the sand....all people will see is an ar5e!!
Post #179441 27th Oct 2012 12:44pm
Page 1 of 3 123>
