Home > Puma (Tdci) > remove DPF ? |
Camara Member Since: 09 May 2012 Location: Batalha Posts: 5 |
I'm having this problem too...
The good thing is that there is a technical information that indicates that this is a problem in the original ECU software. As correction, there is a new software to be downloaded to our cars. I'll try to make it during this week, I hope that it will work. Best Regars João Câmara |
25th Sep 2012 8:09am |
Porny Site Sponsor Member Since: 31 Aug 2009 Location: Sutton Coldfield - West Midlands Posts: 809 |
Removing the DPF isn't a major problem - as you can use Eu3 sofware.
But the standad ECU calibrations are far from ideal!! Ian IRB The home of the first modified Keswick Green 90 - and the first 2.4 Puma through both the 200bhp and 550Nm barriers. www.IRBdevelopments.com www.facebook.com/irbdevelopments www.integrated316.com www.facebook.com/integrated316 |
25th Sep 2012 9:16am |
towfox Member Since: 11 Jul 2012 Location: Limburg Posts: 5 |
@Camara: do you have some further information about the new software?
The landrover dealers here in germany don's know anything about it. |
25th Oct 2012 2:55pm |
Actually, I have some news about this problem.
The problem was ( what they tell me) that the engine oil was to much contaminated. Because of that, the car's software didn't allowed to make the ECU regeneration cycle. I'm not sure if they upload something in the ECU or not... Solution: Oil change with 16000 km and till now, problem solved. P.S.: In 6/11/2012 I will make the 20000km maintenence and LR will replace my turbo in order to solve the famous problem of the loose hose. They will kill an ent with a missile. |
26th Oct 2012 8:08am |
