![]() | Home > Puma (Tdci) > Gearbox issues?? |
Pressure clutch switch (located on the clutch pump, engine bay) Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
Which is pretty much what I said earlier in this thread ![]() Owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. Last edited by Happyoldgit on 25th Oct 2012 1:26pm. Edited 1 time in total |
2 votes for the clutch switch then
![]() But shout it at them in German because life is also terrifying and confusing... |
![]() ![]() ![]() ![]() ![]() ![]() IID Pro MV License |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 ![]() ![]() ![]() |
mine did the rising rev bit. if i recall it was a fuel pressure switch somewhere. the dealer fixed it and never had a problem since then.
don't worry about your new Defender just report the faults and if you have a good dealer they will fix them, i have always had excellent service from my dealer, thankfully. re the clonk i reported a similar issue at my first service as it was not there when i bought it [at 5 months old] but was getting worse. it was just the nuts on the prop/brake drum a tad loose. again no probs since they were tightened. BM52 |
