Home > Maintenance & Modifications > Handbrake Light - Not Going Out
Martyn
United Kingdom 2014 Defender 90 Puma 2.2 PU Keswick Green
Sometimes (not all the time) when I take my hand brake off the light stays on for 10-20 seconds whilst driving then goes out.
The hand brake is deffo down, is deffo slackened off as lowered and nothing appears to be catching the discs.
It all started when I did a few easy but very muddy lanes and got my chasis pretty muddy at the weekend.
What could be up here chaps?
Post #178513 23rd Oct 2012 10:18pm
Glynparry25
Are we talking every time you take the hand brake off? Or only the first time after starting?
The handbrake light doesn't link to the brakes at all- there is a a switch on the back off the handbrake lever which detects the position of the lever- maybe it needs cleaning/ adjusting.
Glyn Dog Sheep
Post #178525 24th Oct 2012 3:20am
Peter Td4
Belgium 2008 Defender 110 Puma 2.4 HCPU Santorini Black
Most likely worn out pads on the rear brakes Wink
Check the brake oil level, this will be low then.
Will only get worse. Peter,
Defender 110 StaWa - Td5
Defender 110 HCPU - Puma
Defender 90 Soft Top - Td5
Post #178526 24th Oct 2012 3:31am
Lishlandy
England 2012 Defender 110 Puma 2.2 X-Tech LE Orkney Grey
My handbrake light flickers on and off almost constantly, is just the switch/sensor is a bit Censored and I either need to give it a clean or replace. Nothing to worry about as far as I'm concerned as its had a service since and friend with a diagnostic reader go into it with no questions being asked as its still 'intermittent'. Very Happy ===================================
Steve
90 xs sw in Stonoway Grey - Sold
110 USW X-TECH
Post #178540 24th Oct 2012 6:35am
me@td5.org
2000 Defender 90 Td5 HT Epsom Green
Post #178549 24th Oct 2012 6:56am
Peter Td4
Might seem daft but I've seen this happen on several Defenders Wink
Anyway, a simple investigation will soon tell why this happens. Peter,
Post #178579 24th Oct 2012 10:31am
SteveT247
England 2002 Defender 90 Td5 XS CSW Bonatti Grey
The hand brake operates on the transmission with its own brake shoes, how will rear brake pads effect it?
Post #178589 24th Oct 2012 11:32am
Martyn
It's only just been 2nd serviced (24k miles). No report of pads needing replacement.
Faulty switch would make sense. If this persists, I'll drop into the stealers.
Post #178592 24th Oct 2012 11:42am
Lishlandy
Eureka!!! ===================================
Steve
110 USW X-TECH
Post #178605 24th Oct 2012 12:31pm
The handbrake light also doubles as a brake fluid warning light so worn pads can mean less fuid in the reservoir. Darren
Post #178611 24th Oct 2012 12:49pm
SteveT247
Thumbs Up Cheers.
Post #178612 24th Oct 2012 12:58pm
Glynparry25
But it wouldn't come on when the hand brake applied and then go off after a little driving- it would come on when the brake pedal is applied as this is when the fluid is in the system and not in the reservoir- opposed to the hand brake which doesn't use the hydraulic brake system.
Sounds like a sticking switch on the hand brake lever (Just need to remove gaiter to check it.
Glyn Dog Sheep
Post #178616 24th Oct 2012 1:25pm
Peter Td4
Indeed Thumbs Up
Sorry Glyn, but if the brake oil level is low the switch will detect this, irrespective if you press the brake pedal or not. Peter,
Post #178618 24th Oct 2012 1:44pm
Glynparry25
But if the level is low enough the light will stay on all the time irrespective of the handbrake where's the OP states that the light goes out after a little driving.
Glyn Dog Sheep
Post #178653 24th Oct 2012 4:06pm
Perhaps he parks on a hill? Darren
Post #178663 24th Oct 2012 4:41pm
