Home > Td5 > No power on start up |
derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 560 |
Disconnect the MAF sensor it's clipped into the air box with the pipe running to the turbo and try then if its ok get a genuine one to replace it
Will 2005 90 XS 1954 86'' Series 1 tilt 1968 88” 2A 200tdi 2002 110 Hardtop |
21st Oct 2012 6:24am |
Chauch Member Since: 10 Dec 2011 Location: Bedfordshire Posts: 51 |
MAF would be the first thing I would check too. Worth taking it off and cleaning it with electrical contact cleaner anyway..
21st Oct 2012 7:13am |
bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3248 |
Hope it is not start of the problem I am getting fixed at the moment
Symptoms Starts first time, blue/grey/white smoke after a number of seconds and feels like it is running on 3 or 4 cylinders. Once clear it is fine. Oil/water levels etc all OK. Jobs done. New genuine MAF - helped a bit. Cleaned the MAP sensor - helped a bit. Injector seals replaced - they were shot (see picture in my post if it is not broken fix it !) - can't tell if it helped as I have not had the vehicle back because of .... Turbo shot Not spooling up correctly and allowing a build up of oil/diesel that is then suddenly blasted into the engine causing smoke etc. Once cleared it was fine. Not seen the old turbo but it sounds like the bearings have gone, probably due to the previous little old lady owner not getting the thing serviced for over five years Just before it went in I was also getting some strange noises from the front near side that I put down to the wiring work I had done and something catching/rubbing. I am wondering if I could hear the turbo blades rubbing in the casing ? Might be worth checking the turbo impeller for movement and not catching on the casing. Hope it is not this and something a lot easier and cheaper to fix Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
21st Oct 2012 8:00am |
Laurie Member Since: 22 Feb 2008 Location: Sussex, England Posts: 2897 |
Thanks guys.
Useful info as usual. Will try and report back. |
21st Oct 2012 9:58am |
