Home > Maintenance & Modifications > Flip down side steps? |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4700 |
If you are worried about a slight lean by one side or the other or both don't be, standard fit arrangement.Hope to get them photographed and uploaded this weekend, unless someone beats me to it. 1982 88" 2.25 diesel
12th Oct 2012 6:32pm |
Have not forgotten, trying to locate the lead to connect the camera to the laptop - (again) 1982 88" 2.25 diesel
18th Oct 2012 7:08pm |
db950 Member Since: 01 Feb 2012 Location: Lincoln Posts: 560 |
Hi the genuine land rover side steps don't bolt through the top floor plate bolts but bolt through the back of the sill channel.
18th Oct 2012 9:25pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6093 |
HI all
Yeah, I had a browse through RAVE and found the install instructions, and see as DB950 says, they bolt through the back of the channel. All I really need now is the distance from a reference point to the bolt holes (just so I can fit them in the factory position) cheers |
19th Oct 2012 6:58am |
Can take the measurements off mine when I get in later if that helps.
19th Oct 2012 7:07am |
Welshsurferdude Member Since: 23 Feb 2012 Location: Newport Posts: 2411 |
they do indeed bolt to the back channel of the sill, just fit em roughly in the middle of the door and see which holes they line up to.
i fitted mine last week and only took me 5 mins per step without looking it up 2008 Santorini Black 110 XS USW (Sold) 2015 Discovery 4.5 Black pack Firenze red XS 2008 Corris Grey 110 XS USW (sold) 2011 Santorini Black 110 XS USW (Sold) |
19th Oct 2012 7:38am |
Cool. I did wonder if the sills were already pre-drilled. must crawl underneath and have a gander.
19th Oct 2012 9:22am |
Get under there and wiggle it about til the holes line up steps might need a lil persuasion but that's Lr for you, holes are pre drilled 2008 Santorini Black 110 XS USW (Sold)
19th Oct 2012 9:41am |
farmer giles Member Since: 09 Feb 2011 Location: worcestershire Posts: 1299 |
yep, holes definately pre drilled; i retro fitted 4 on my 110.
did need to use a rivneut tool to install nuts in the chassis though. |
19th Oct 2012 11:57am |
Thanks all.
The steps are currently drying in the garage (fresh coat of black paint), will get them on later. |
19th Oct 2012 2:02pm |
walfy Member Since: 29 Aug 2007 Location: Frome Posts: 2661 |
I have a big rivnut tool if you need to borrow Jamie. 110 D250 SE HT
110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
19th Oct 2012 2:30pm |
Got one here cheers Mark
19th Oct 2012 3:28pm |
