![]() | Home > Maintenance & Modifications > Snow cowl |
familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3481 ![]() ![]() ![]() |
Fitted Mud one today. Also fitted my mates one.
Great value at £35 Also took time to fit Brendan's rear door piston assembly. Kids won't be smashing the door closed now!! 1951 80" S1 2.0 1995 110 300TDI 1995 90 300TDI |
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 ![]() ![]() ![]() |
25/12/2013 ![]() ![]() www.cskautomotive.co.uk Like us on Facebook - www.facebook.com/csklr Follow us on Instagram - @cskautomotive |
Defender-Stu Member Since: 14 Jun 2012 Location: South West England Posts: 1320 ![]() ![]() |
Easy to fit and how long did you have to wait? |
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 ![]() ![]() ![]() |
Ordered an ex M.O.D one from Blanchards today ready for winter hoping it will help stop misting up inside. 2005 Td5 90 XS
Steve |
There is no easy simple ways of preventing theft of bolt on equipment or of complete vehicles. Whatever security methods you decide on please consider how your security means may impinge on you wanting to adjust/remove/repair your vehicle. There are many security fixings around, some 'permanent or one way' such as clutch screws, sentinel etc or reuseable ones, pin hex, 2 pin, 4 pin, 6 lobe, pin torx etc. OK if Mr Scumbag turns up properly tooled up they can still nick your belongings but at least it will slow down/deter the opportunist thief. Brendan |
Took 5 mins to fit and arrived the day after I ordered - unbelievable service. 1951 80" S1 2.0 1995 110 300TDI 1995 90 300TDI |
Landlord Member Since: 27 Oct 2009 Location: Hampshire Posts: 582 ![]() ![]() ![]() |
[quote="familymad"]
Ditto mine arrived today 24 hrs after ordering from Mud. Looks like it will be straight forward fit and will do the job before leaving on the trip 2007 TD5 90 Hard Top Last edited by Landlord on 22nd Oct 2012 7:46am. Edited 2 times in total |
What holds the gasket in place or stops it moving out of place ? |
double post...sorry
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20645 ![]() ![]() |
Besides the obvious (snow) is there any other advantages to having one? TheThunder Rollsπ¬π§πΊπΈ
β½οΈπ’οΈβοΈπ§°πͺ |
Keeps general rubbish out which would otherwise eventually block the drain, which in turn causes it to leak inside when it rains. Darren
I'm guessing that water ingress will also play havoc with rust in the heater internals over time, so fitting one early on and leaving it there all year will have a positive preventative effect (or may just be a case of man maths again!).
RRUK Site Supporter Member Since: 31 Mar 2010 Location: Leicestershire Posts: 2025 ![]() ![]() |
When you have removed the old vent on the top, get your arm inside the heater intake and check for leaves etc. Also, there is a small rubber vent hole in the bottom corner by the heater mating to allow for drainage which can easily block up with silt and mud deposits so get your little pinkie in there and make sure water can run out freely, otherwise your heater will expire from rust a lot sooner. 2016 D4 HSE
1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
WarPig Member Since: 04 Dec 2009 Location: Sheffield Posts: 1748 ![]() ![]() ![]() |
Got mine from P A Blanchards. Sprayed it Bonatti grey to match...
![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
