Home > Puma (Tdci) > Sweating Passenger floor...
superspoons
England 1998 Defender 90 V8 Petrol 50th Auto Atlantis Blue
Hi all,
The front carpet under the passenger side of my 110 is always slightly damp underneath. Not much, like the usual water ingress in Defenders, but enough to make it smell unpleasant. Drivers side is fine.
I've took it all out and looked for leaks etc but only the carpet nearest the seat-box seems to be affected. Can't see any visible gaps etc. I've had it all dry, only to revert to damp in a matter of days with only minimal rainfall.
Anyone else had this??? Cheers,
Superspoons
Post #161762 14th Aug 2012 5:03am
derek
United Kingdom 2007 Defender 90 Puma 2.4 XS CSW Santorini Black
Check posts for AC drain blocked as it soaks passenger footwell
Derek
Post #161790 14th Aug 2012 8:37am
K9F
derek wrote:
Check posts for AC drain blocked as it soaks passenger footwell Derek
Better still.....
http://www.defender2.net/forum/topic14249.html?highlight=drain If you go through life with your head in the sand....all people will see is an ar5e!!
Post #161793 14th Aug 2012 8:45am
derek
cheers couldn't remember the exact post
D
Post #161795 14th Aug 2012 8:47am
K9F
Remembered the photos of the cut drain and the fact it wasn't too long ago....keyword was 'drain'..... Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #161800 14th Aug 2012 8:53am
Grockle
don't forget it's single skin and will get condensation under the carpet or mat. 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #161804 14th Aug 2012 9:24am
superspoons
Yes, but why isn't it happening on the drivers side though Question
I'll get under there tonight and look for the drain plug anyway.
Thanks all, Cheers,
Superspoons
Post #161822 14th Aug 2012 11:25am
Has anyone extended the pipe so that it can drain directly underneath the vehicle rather than run down the gearbox?
Post #176557 17th Oct 2012 4:16pm
Harryb450
United Kingdom 2011 Defender 110 Puma 2.4 USW Santorini Black
i put a few sheets of newspaper under the mats, this soaks up any damp. and change it every month or so Thumbs Up Thumbs Up
Post #176611 17th Oct 2012 6:59pm
lol...that takes me back a few years...don't suppose you use old underlay under your carpets for sound proofing as well Laughing
Post #176636 17th Oct 2012 7:51pm
Harryb450
Rolling with laughter Rolling with laughter Rolling with laughter
Post #176653 17th Oct 2012 8:17pm
