Home > Puma (Tdci) > Sweating Passenger floor... |
derek Member Since: 13 Jan 2012 Location: Beckenham kent Posts: 94 |
Check posts for AC drain blocked as it soaks passenger footwell
Derek |
14th Aug 2012 8:37am |
Better still..... http://www.defender2.net/forum/topic14249.html?highlight=drain If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
14th Aug 2012 8:45am |
cheers couldn't remember the exact post
D |
14th Aug 2012 8:47am |
Remembered the photos of the cut drain and the fact it wasn't too long ago....keyword was 'drain'..... If you go through life with your head in the sand....all people will see is an ar5e!!
14th Aug 2012 8:53am |
Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266 |
don't forget it's single skin and will get condensation under the carpet or mat. 2.4 90 XS
14th Aug 2012 9:24am |
superspoons Member Since: 16 Apr 2012 Location: Herts Posts: 314 |
Yes, but why isn't it happening on the drivers side though I'll get under there tonight and look for the drain plug anyway. Thanks all, Cheers, Superspoons |
14th Aug 2012 11:25am |
Has anyone extended the pipe so that it can drain directly underneath the vehicle rather than run down the gearbox?
17th Oct 2012 4:16pm |
Harryb450 Member Since: 11 Dec 2011 Location: over yonder Posts: 283 |
i put a few sheets of newspaper under the mats, this soaks up any damp. and change it every month or so
17th Oct 2012 6:59pm |
lol...that takes me back a few years...don't suppose you use old underlay under your carpets for sound proofing as well
17th Oct 2012 7:51pm |
17th Oct 2012 8:17pm |
