Home > Maintenance & Modifications > Anderson connector on seatbox |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8582 |
Yes I will admit that the red 110 battery box is not the neatest, it has evolved over time. However it was not built as a show vehicle but as a overland vehicle and it has proved its worth in the field so to speak.
A quick word of caution, please note that different colours of Anderson connectors will not readily match with each other. Brendan |
16th Oct 2012 8:13pm |
mobilecentre Member Since: 05 Mar 2012 Location: Evesham Posts: 645 |
The use of bus bars prevents the dead octopuses in the seat boxes.
On mine I have front and rear jump leads, blue sea fuse box then additional power running out to another Blue sea fuse box with all the earths also returning back to bus bars. Both batteries are also fused. Another word of warning on Andersons is they are coloured to denote application voltage with yellow being 12V, |
16th Oct 2012 9:49pm |
udderlyoffroad Member Since: 18 Jul 2011 Location: Bristol Posts: 124 |
Where have you positioned your octupus-traps (busbars) Tim? Any chance of some piccies? I too plan to have Andersons mounted front rear and centre as my seats will not be OE and therefore the bases will not be removable. Matt Real trucks don't have spark plugs |
18th Oct 2012 3:29pm |
Left side of the seat box looking in from the door
Click image to enlarge Right side Click image to enlarge |
18th Oct 2012 3:51pm |
Awesome, thanks Tim. Will try to make my installation as neat as yours! Real trucks don't have spark plugs
18th Oct 2012 6:11pm |
We carry the bus bars, fuse holders, batteries, Blue Sea relays, twin battery trays etc all in stock if you need anything
18th Oct 2012 6:17pm |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5850 |
Good idea on the bus bars, but I would like some kind over cover over the top of the positive connectors just in case.. 1999 Defender TD5 110
18th Oct 2012 7:27pm |
You mean one of these
18th Oct 2012 7:32pm |
Yup those are the puppies. 1999 Defender TD5 110
18th Oct 2012 7:34pm |
