![]() | Home > Technical > HELP! Front hub removal problems |
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 785 ![]() ![]() ![]() |
Have you removed the big 38mm? nut
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8171 ![]() ![]() ![]() |
there is no nut holding the drive member on, just the circlip
can you not rotate the DM and then get in behind on the flat edge/lip that is exposed when it is out of sequence? i large pry bar and lump hammer will do it eventually. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
Toplink Member Since: 05 Dec 2010 Location: Somerset Posts: 159 ![]() ![]() |
The FBN is behind the driving member.
Use an angle grinder with a very thin disc and slowly cut through the driving member from front to back ,carefully to avoide damaging the hub or half shaft.it is impossible to avoide a few nicks,these will not affect the components.When you have cut a number of slices beat the slots now prwesent in the drivivng member using a hammer and cold chisel. It works. I remove my dust/hub caps every service and grease the splines and my sure they are free. FBN = F ![]() 2007 Defender HTop. 1952 Series One 80" 1977 Muir-Hill 111. 2014 Triumph Tiger800xc 1999 Discovery 2 td5 1982 Ransomes TSR300D. 2002 Yamaha XT600e. 2010 Freelander2 (the wifes) 2008 John Deere X140 |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17606 ![]() ![]() ![]() |
Try using a hammer and drift to rotate the drive member until you can use a puller to pull the DM off the halfshaft.
Absolutly correct, note to self: must read properly before posting ![]() |
put it in gear and attempt to drive it with foot break on no diff lock. or use extended bolts and a pry bar to lever it around Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
