![]() | Home > Maintenance & Modifications > Heated mirrors |
Phoenix90 Member Since: 04 Mar 2012 Location: Cornwall Posts: 377 ![]() ![]() ![]() |
They do work well, and really help to stop mirrors fogging up.
You could take a feed off of the heated windscreen to switch a relay but I wouldn't take the feed directly. I'm not sure what power they are but wouldn't want to increase the circuit load of the heated windscreen personally. Also, I to leave my heated mirrors on for a long period of time, much longer than the front heated windscreen stays on for so would want them wired in a different way. |
mobilecentre Member Since: 05 Mar 2012 Location: Evesham Posts: 645 ![]() ![]() |
Most of the heated mirror kits are fairly low draw around 1A per side so could be switched directly without the use of a relay.
Tim |
@Phoenix - did they work ok in Nordkapp or did your side windows obscure the mirrors ?
I've been reading about the snow plough runs and they recommend you keep you car cold ![]() |
I have them fitted and think the work really well.
I noticed when I lived in Scotland I would de-ice the mirrors and within 5-10mins they were frozen again, so great in my eyes ![]() I have mine wired in with the heated front screen. Russell 2011MY 110 XS USW Black |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6126 ![]() ![]() ![]() |
I reckon that heated mirrors are much more worthwhile than the heated screen.
boode Member Since: 11 Apr 2012 Location: Devon Posts: 434 ![]() ![]() ![]() |
My heated mirrors are wired into a new dash switch and they stay on when its cold, could also wire then to come on with the rear demist - which is on most of the time.
Also noticed that the warm mirrors also dispel the rain / mist when normal driving. bpman - mirrors worked well in Norway untill the side windows froze - at about -35, they were still clear but could not be seen through the 1/4 inch of ice on the inside. But the heating on your Tdci is better than the Td5s so it may keep the side windows clearer. The MUD UK elements come with a relay, wires etc Last edited by boode on 12th Oct 2012 8:20pm. Edited 1 time in total |
The mud uk ones are what I have fitted
![]() 2011MY 110 XS USW Black |
Has anyone got any pics of how the wiring runs from the mirrors and through the hinge?
Cheers Ray |
Jake at Devon 4x4 did an excellent article on wirring through the mirror stalk and then through the hinge - lots of pics - I used it and it keeps the wires hidden. I had a quick look on their web site but could not find it so if you email Jake I am sure he will point you to it - they sell the mud kits as well. |
Try this
http://www.defender2.net/forum/topic10802-15.html Russell 2011MY 110 XS USW Black |
As boode says they worked well - though we never had the 1/4 inch of ice on the inside ![]() The bit they where best for was in the tunnels. If your going E6 you'll be going through a lot of tunnels, as the air is a slightly different temperature in there almost as soon as you drive in your side mirrors will fog over totally. We learn't to turn the mirror heating elements on whenever we where approaching a tunnel to help stop them fogging over. Simple but effective mod, definitely worth it ![]() |
In ordinary cars, heated mirrors are usually connected to the rear heated screen. Taking a feed of that via a relay would seem like a reasonable approach. The relay could even incorporate a timer if desired. Darren
Found the thread of Jakes install - very tidy as all weires are hidden in mirror stalk
http://www.devon4x4.com/index.php?option=c...d=81#82291 You need to register to see pictures |
Can't get the link to work ![]() ![]() |
