Home > Puma (Tdci) > Taking a leak... |
willy eckerslike Member Since: 15 Jun 2009 Location: North yorks Posts: 1789 |
Happens on some quite often, my 110 has had two in 38k Original Member Pie n Pea Club.
110 HCPU Tipper |
6th Oct 2012 5:29pm |
Defender-Stu Member Since: 14 Jun 2012 Location: South West England Posts: 1320 |
Had this on my TD5 D2 and my mate Steve hill sorted it within 10 mins with a new seal give him a call mate should not be expencive and it happens and sorry in advance if I seem a little short but hope that was not implying Steve had something to do with it?
6th Oct 2012 5:38pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20121 |
Willy - Typical it is only just sorted out my EGR valve issue and then this
Stu - How much do you reckon roughly? Anyone know the name / part number of the seal at all? From what I read up earlier this afternoon I thought's it was known as the Pinion Seal but I'm no expert NEVER SURRENDER! ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
6th Oct 2012 5:45pm |
Stu - Don't worry either way I'm not implying anyone did anything it's probably just where things have been moved around during service and new fluids I just thought it is something that need's to be sorted out all the same or all the oil will drain NEVER SURRENDER! ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
6th Oct 2012 5:48pm |
The seal comes out with out the loss of the oil as the oil comes out while driving and the seal is about a tenner maybe if that and Steve would prob only charge 40 all in bud
Sorry mate did not mean to be forward its just Steve is a good friend and is the best land rover skilled person I know and he has so much business and he is not like some people I know that mess cars up so people have go back and spend more money Try his number now as he some times works late |
6th Oct 2012 5:55pm |
Ahh, good news then Stu I won't right now but probably Monday. Don't get me wrong as I said it's probably due to the service just because things get moved a bit (obvious really) so then if the seal is toward the end of it's life it will of course go. I understand what your saying and I'm pointing no fingers. I think from what I can remember he said when I picked it up that there was a "slight leak" at the time but to be honest with you I can't quite remember now. Since of course I've been driving it so has probably become a bit more of a leak since. The actual service I had done I'm very pleased with running great and smooth as anything now and since I fitted my own new EGR and sorted that out it's been absolutely perfect. NEVER SURRENDER! ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
6th Oct 2012 6:10pm |
The movement was prob to do with dragging the tree out and put a little more strain then normal, my td5 rear and front seal went and by the time I found the leak I did 3 play days and 1000 miles and when me and Steve got her on the ramps it was hanging out lol, spend 5 hours on other leaks and issues and then drove 45 mins home, went to put my drivers window up and pop the window reg gave up lol, so that week I gave Steve my spare key to come get it as I thought I had bought a sh** box and he went through it with a tooth Combe lol and then had it back all done then tuned it and drove it hard and was smoother then before due to Steve
6th Oct 2012 6:44pm |
Stu The tree is not all I've pulled out recently so that probably explains it but at least it gives all the components a bit of proper use so keep everything going well. Pulled out a loaded AA van from mud and a car a couple of weeks back so your probably right. (not at the same time) Other than this leak it's sweet as a nut right now running and driving wise The steering is a lot better too than it was even though there was nothing wrong anyway it seems lighter and smoother. NEVER SURRENDER! ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
6th Oct 2012 9:48pm |
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 |
Custom 90 steve it may be worth checking your axle breather is not blocked ! if it is as your diff heats up and the oil/air expands it will have to vent somewhere and the seal is the easiest place to release pressure.I changed a pinion seal twice before i worked it out. 2005 Td5 90 XS
Steve |
6th Oct 2012 10:03pm |
That's true I must do that. How easy / difficult is the breather to remove axle end? NEVER SURRENDER! ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
6th Oct 2012 10:07pm |
Real easy it is threaded and just undoes in the normal manner.The tube was blocked on mine (rear) with road crud.Its certainly easier than changing the seal ! 2005 Td5 90 XS
Steve |
6th Oct 2012 10:12pm |
Forgot about that bit lol, we'll you were talking about the breather kit from D44 lol, might a good little investment but if the seal has started to leak then replace it anyways mate as it won't stop 100%
6th Oct 2012 10:20pm |
Mine stopped leaking as soon as i cleared out the blockage but i,d already changed the seal twice by then ! 2005 Td5 90 XS
Steve |
6th Oct 2012 10:27pm |
Either way checking the breather is a good logical place to start all the same. It might or might not be blocked. If not it'll be the seal. If it is i'll clear the breather out and I'll clean the leak up and see what happens. If it re-appears after that then the seal needs doing too. Thanks for the pointers chaps especially the breather. never though of that myself. NEVER SURRENDER! ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
6th Oct 2012 10:45pm |
