Home > Maintenance & Modifications > Colour of Dinitrol.... |
SGH Member Since: 27 Sep 2010 Location: Hellingly-Sussex Posts: 1527 |
Thinner first coat ML is brown and 4941 wax is black...
Well that's what I have here (since March) ready and awaiting to be applied. Just waiting for some enthusiasm to do it still. 993 Varioram - Guards Red Defender 2.5 300TDI 110 HCP - Keswick Green Defender 2.2 TDCI 130 HCP - Orkney Grey - GONE Discovery 4 SDV6 HSE LUX - Corris Grey/Black Pack - GONE Discovery 4 SDV6 HSE LUX - Montaciano Red/Black Pack - GONE |
1st Oct 2012 2:31pm |
Mine was Dinitrolled professionally, so don't know the product nbrs. But underside finish is all brown, while inside of the rear crossmember as well as the front bumper, inside of doors, A,B,etc. frames is all a fairly transparant bit whitish wax. Nothing black at all. Also take a look at Zagato's Dinitrol sticky.
Click image to enlarge You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
1st Oct 2012 3:48pm |
stevie d Member Since: 09 Nov 2009 Location: Bishops Stortford Posts: 342 |
Hi,
3125 is the brown cavity wax. You can use the 3125 over the whole vehicle and then finish the hard wear areas with the black 4941 if you wish. The black does give a very nice finish but is not wholly necessary as the brown is also hard wearing in my experience. I would suggest buying 2:1 brown to black. Steve Defender 90 TD5 Station Wagon Discovery 3 HSE BMW 330i Coupe |
1st Oct 2012 5:23pm |
leonski Member Since: 14 Dec 2009 Location: Northumberland Posts: 205 |
Thanks guys!
I had read Zagato's Dinitrol sticky and I had seen other images some being brown and others being black...now I understand why. I had decided to get the kit he suggested as it seemed the best thing to do. Now all I have to do is keep my fingers crossed for a couple of dry days! Cheers, Leon. |
1st Oct 2012 7:28pm |
mermoto Member Since: 21 Sep 2011 Location: Essex Posts: 326 |
To do it well, apply RC900 first to any rusty areas to convert the rust!
Then apply the softer brown stuff inside cavities and outer surfaces then cover it with the black stuff. Result = soft flexible coating against the metal and the drier flexible more resiliant coating with the proper finish on the outside. Simples Lovely stuff to use and doesn't stink like Waxoyle which incidently I also like but only in cavities. Click image to enlarge Mermoto |
1st Oct 2012 8:18pm |
Just ordered some ACF-50 with pump spray must get this done before weather really turns.. 993 Varioram - Guards Red
1st Oct 2012 8:35pm |
Peter Member Since: 04 Mar 2012 Location: Kent Posts: 153 |
Or yo could ask Mick to do it.He is just down the road from you!
. Underbody protection. Google it. Or add co.uk He only uses dinitrol. Last edited by Peter on 1st Oct 2012 10:24pm. Edited 1 time in total |
1st Oct 2012 10:22pm |
I've asked Mick but he wants £800+ to do a 130 993 Varioram - Guards Red
1st Oct 2012 10:23pm |
sparkylee Member Since: 06 Nov 2010 Location: surrey Posts: 1455 |
Pm sent SGH It's good to be back from the dark side
DC110 -2012 Black with black hood and black x-tech FFRR 4.2 vogue Renault traffic auto PT crusier convertible Laika x700 Motorhome |
1st Oct 2012 10:30pm |
might consider that. 993 Varioram - Guards Red
1st Oct 2012 10:32pm |
chadjizz Member Since: 25 Apr 2012 Location: sussex Posts: 559 |
is the dinitrol kit better than wax oil? im looking to put it on a brand new landy before it goes anywhere... so no rust to core in the first place (well i hope so but never know what they do in the factory, its taken 6 months to get mine ready!)
3rd Oct 2012 8:51am |
Yes Dinatrol is better than Waxoil 993 Varioram - Guards Red
3rd Oct 2012 8:53am |
thanks si, dinitrol it is then.
p.s. hopefully the truck will turn up this month!!! |
3rd Oct 2012 6:48pm |
Done it!
A pretty messy job, but not as bad as I thought it was going to be!..... Didn't use a lot of the 4941 but used all of the ML wax. The gun that was supplied with the kit was a bit crude and even with the compressor turned down it still laid it on thick! So I only put the 4941 on places that are going to get a hammering or needed extra protection (diffs, front end...basically anything that was showing wear). Looks a bit like its made from liquorice in places now, but it really gets a hammering over the winter with our cruddy country roads and the shed loads of salt they spread, more protection the better! |
6th Oct 2012 8:22pm |
