![]() | Home > Technical > Diff oil change and magnertic plugs |
***Edit***
I gave them a quick call on your behalf as it costs me nowt....They too agreed 60Nm was too much. It is not a clear defined art apparently. The plugs are going into a tapered thread and you should wind it in so the thread on the plug itself is not exposed. Basically 'Tighten it until it doesn't leak' was what was explained to me direct. ********* I bought a Femco Drainplug System for the sump that clearly states that a torque setting of 20 footpounds should be used. You could possibly use that as a guideline. 'Better to go lower' (as Killer90 would say ![]() http://www.drainplug.co.uk/accessories.html ![]() Treat every day as if it is your last....one day you will be right!! Last edited by K9F on 1st Oct 2012 11:27am. Edited 1 time in total |
mermoto Member Since: 21 Sep 2011 Location: Essex Posts: 326 ![]() |
Good question and a good answer, I expect it is one of those 'tighten using an experienced hand'
In the absense of any defined setting....'Half a white knuckle' normally does the trick.....Which applies in this case I think.
![]() Treat every day as if it is your last....one day you will be right!! |
o4dn Member Since: 08 Jan 2010 Location: South West Posts: 554 ![]() ![]() ![]() |
Many thanks!
Welcome. ![]() No need to thank, had a bit of time on my hands, all it cost me was five minutes or so of my time.... only too glad to be of assistance. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
stevie d Member Since: 09 Nov 2009 Location: Bishops Stortford Posts: 342 ![]() ![]() ![]() |
Hi,
I have these plugs and fiited with 18/20lbft as original plugs - but they seemed to leak!! I have since tightened them further, leak seems to have stopped. They seem to be made of very soft alloy - got a bit of swarf at the spanner end. Steve ![]() Discovery 3 HSE BMW 330i Coupe |
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 ![]() ![]() ![]() |
Just a word of caution to anyone thinking of changing their own diff and gearbox oils always make sure you can get the filler plug undone first ! have seen a few vehicles in the workshop at work where people have managed to drain their oil but have been unable to refill it. 2005 Td5 90 XS
Steve |
Yorkshire90 Member Since: 22 Sep 2011 Location: West Yorkshire Posts: 193 ![]() ![]() |
Bringing thread back to life. Fitting my magnetised femco plug to my td5 sump in an hour. States 25 ft lb of torque which comes out at 33nm... Standard plug is 23 nm iirc. Seems a big hike... Going to add some blue loctite and tighten to 23 nm first... See how it feels. Thoughts? "Big green" 2000 Td5 90 IRB Developments modified (2004-2011)
Discovery 3 TDv6 GS Auto 2011-2012 *Missed the Defender too much* IRB Developments rebuild: Project Ice cube 2012-...... http://www.defender2.net/forum/topic11056.html |
