Home > Puma (Tdci) > Vague Steering |
cradgebank Member Since: 30 Dec 2008 Location: Nottingham Posts: 308 |
I presume you are referring to when the engine is running, if so you have a problem, maybe a failed track rod, a steering box problem, panhard rod bush or wheel bearing failure.
Suggest you get it checked ASAP. Richard Either a 90, 110 or 130. Discovery 5 |
25th Oct 2009 11:55pm |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
Get somebody to move the steering wheel with the engine off and you check what moves and what isn't moving you easily see where the problem might be. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
26th Oct 2009 8:17am |
willy eckerslike Member Since: 15 Jun 2009 Location: North yorks Posts: 1789 |
I believe you can adjust or get adjusted the steering box if the plays there. Well at least you used to be able too Original Member Pie n Pea Club.
110 HCPU Tipper |
26th Oct 2009 9:21am |
Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266 |
It's still in warranty,I'd take to the dealer. 2.4 90 XS
26th Oct 2009 10:46am |
Ads90 Member Since: 16 Jun 2008 Location: Cots-on-the-Wolds Posts: 812 |
There is some adjustment I think - I mentioned excessive steering play when mine was last serviced - they said they checked it and found nothing actually at fault but were able to make some adjustment (don't know what) - it did improve it to acceptable straight-ahead levels, there's still an inch or two of play at full lock though... |
26th Oct 2009 11:20am |
Willie Member Since: 08 Oct 2009 Location: Stockton Posts: 48 |
5.00pm and its dark. I'll look underneath tomorrow and then take it to the dealer for him to check/adjust. The car seems to live at the dealers these days!
I'll keep you updated. Willie Defender Virgin |
26th Oct 2009 5:10pm |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3708 |
Chelsea had to have new track rod ends as she was suffering from vauge steering, I think she had them changed at about 8k
26th Oct 2009 6:06pm |
Got car back from dealer today. Steering much better, said they adjusted something. Whatever it was they adjusted it worked.
29th Oct 2009 10:51pm |
