Home > Puma (Tdci) > Vague Steering
Willie
United Kingdom 2007 Defender 90 Puma 2.4 CSW Rimini Red
Vague Steering
How much steering wheel movement should there be before the wheels move. My 2007 Puma which has done about 8K has about 3" of play before it takes up the slack. Is this normal? What if anything should I check?
Willie Defender Virgin
Post #17209 25th Oct 2009 11:21pm
cradgebank
England 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
I presume you are referring to when the engine is running, if so you have a problem, maybe a failed track rod, a steering box problem, panhard rod bush or wheel bearing failure.
Suggest you get it checked ASAP. Richard
Either a 90, 110 or 130.
Discovery 5
Post #17211 25th Oct 2009 11:55pm
roel
Get somebody to move the steering wheel with the engine off and you check what moves and what isn't moving you easily see where the problem might be. Roel
2003 90 Td5 (2009-now)
Post #17219 26th Oct 2009 8:17am
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
I believe you can adjust or get adjusted the steering box if the plays there. Well at least Thumbs Up you used to be able too Original Member Pie n Pea Club.
110 HCPU Tipper
Post #17220 26th Oct 2009 9:21am
Grockle
It's still in warranty,I'd take to the dealer. 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #17228 26th Oct 2009 10:46am
Ads90
United Kingdom 2007 Defender 90 Puma 2.4 CSW Keswick Green
There is some adjustment I think - I mentioned excessive steering play when mine was last serviced - they said they checked it and found nothing actually at fault but were able to make some adjustment (don't know what) - it did improve it to acceptable straight-ahead levels, there's still an inch or two of play at full lock though...
Post #17233 26th Oct 2009 11:20am
Willie
5.00pm and its dark. I'll look underneath tomorrow and then take it to the dealer for him to check/adjust. The car seems to live at the dealers these days!
I'll keep you updated.
Post #17244 26th Oct 2009 5:10pm
AndrewS
Chelsea had to have new track rod ends as she was suffering from vauge steering, I think she had them changed at about 8k
Post #17247 26th Oct 2009 6:06pm
Willie
Got car back from dealer today. Steering much better, said they adjusted something. Whatever it was they adjusted it worked.
Post #17476 29th Oct 2009 10:51pm
